Old 09-11-2014, 04:45 PM   #1
1982 27' Excella
Huntsville , Texas
Front tongue electric jack
I just purchased a 1982 Excella with an electric tongue jack. I am pulling with a chevy 1 ton pickup. The bottom of the electric jack, which appears to be the original jack, is only 3 to 4 inches off the ground when hooked up. The bottom of the jack appears to be welded on. I am concerned that I will hit something and damage the jack when I am on the road. Can the ground clearance be increased? If so how can I increase it?
GMarugg is offline   Reply With Quote
Old 09-11-2014, 05:17 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
You have a legitimate concern...that's not much clearance. The jack post (the part that goes up and down) should retract pretty much all the way into the body of the jack (the stationery part).
A couple of thoughts: It's possible that for some reason the post is not retracting all the way. I'd make sure the jack foot isn't just stuck onto the post. Depending on the design of the foot it can add several inches to the post.
TB & Greg and Abbey Schnauzer
#3954
Old 09-11-2014, 05:30 PM   #3
2005 30' Classic
Burlington , Ontario
If the jack is working properly and you still have this problem, perhaps someone relaxed the jack and created the situation?
May be a "Mickey mouse" solution, but if all else fails and you are still concerned, perhaps you could just cut a couple of inches off the bottom of the moving post with an angle grinder (after first ensuring you have lots of travel) then use a large wooden block (or a few of those interlocking plastic leveling blocks) if need be to get the height you need when dropping the jack down to release the trailer from the hitch ?
Brian.
Old 09-12-2014, 06:20 PM   #4
1982 27' Excella
Huntsville , Texas
Front Tonge Electric Jack
The guy that I purchase the trailer from said that he thought that it was a travel limit switch setting that needed to be adjusted but when I looked closer at the jack the traveling portion was being retracted into the top sleeve until the bottom sleeve came into contact with the top sleeve, ie the traveling portion of the jack was completely enclosed so the jack could not travel anymore. The bottom plate appears to be welded on and the sleeve appears to have been crimped to the traveling portion. Anyway I was not able to knock the bottom portion off of the jack. My thought was to remove the bottom portion an trim it so that could rise higher before hitting the outer sleeve of the top portion
Old 09-12-2014, 06:54 PM   #5
1987 25' Sovereign
Oregon , Ohio
If it is the original jack with the trailer you might think about a new jack.
msmcv51 is offline   Reply With Quote
Old 09-12-2014, 07:21 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I think the thing that is crimped on is actually not crimped, but is dimpled. The dimple goes into a vertical slot on the shaft then rotates into a horizontal slot. The jack foot plate should come off of the jack shaft. On one of my prior trailers it would get rusty and filled with mud then get stuck. Try spraying it with some WD40 and let it set a while. Then, with the trailer hitch resting on the hitch ball raise the foot plate about an inch off the ground and bang on the foot plate a few times with a hammer. You may have to rotate the foot plate about 1" to get the dimple aligned with the vertical slot in the tube so it will drop off. If this works it should give you 6" more clearance.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 09-12-2014, 07:26 PM   #7
Zweihighkid's Avatar
1978 Argosy 30
Pine bluff , Arkansas
I have an electric jack and I use the wooden block method!! Works for me!!
Zweihighkid is offline   Reply With Quote
Old 09-13-2014, 04:00 PM   #8
1982 27' Excella
Huntsville , Texas
Thanks for your words of wisdom. Knowing it was suppose to come off, penetrating oil, pipe wrench and hammer it did come off. I now have plenty of ground clearance. The guy I bought the trailer from did not know that it was suppose to come off so it had been on there a minimum of 12 years. Once again thanks
Old 09-13-2014, 10:46 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
As an FYI...
We bought a 7" cast aluminum jack stand based on a vintage design from a family that produces them in Indiana... The jack post sits inside a lip at the top and gives great stability to the jack.
The original maker has unfortunately passed away his family is still producing them...they make a 4" and a 7" version... I am happy to provide the ordering info ... if you are interested, PM me.
Name:	Cast Aluminum Jack Stands.png
#3954
Old 09-14-2014, 04:18 AM   #10
sandlapper's Avatar
1993 34' Excella
York , South Carolina
I purchased one of their Jack stands also. Works great, not expensive, and retro cool. Costs more than some wooden blocks stacked up but sure does look and work better. Money well spent.
john
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 09-14-2014, 05:07 AM   #11
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
For a long time I had to beat the foot off the jack with a hammer every time.
Eventually it became one good whack with the hammer.
Now I can get off by hand or it stays on the ground when the jack is raised.
I think it was new/tight/stiff and has now worn/warped/bent/wallowed out a little-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-15-2014, 09:14 AM   #12
1982 27' Excella
Huntsville , Texas
I did get if off with penetrating oil, a pipe wrench and large hammer. I was hoping that if I greased it next time would not be a problem.
manual crank for 1964 electric tongue jack Croverlander 1960 - 1964 Overlander 15 04-09-2014 11:10 AM
Installing a new ultra 3002 electric tongue jack on my 65 Caravel toastie Jacks, Stabilizers, Lifting and Leveling 3 03-15-2007 11:10 AM
Electric tongue jack help RVnDixie All Argosy Trailers 8 12-31-2006 08:54 PM
Electric Tongue Jack darryl97420 Jacks, Stabilizers, Lifting and Leveling 0 05-25-2006 08:57 PM
Electric tongue jack not extending ipso_facto Jacks, Stabilizers, Lifting and Leveling 5 03-25-2003 11:58 AM
