Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella > 1981 - 1983 Excella
Old 12-06-2007, 03:26 PM   #1
jonesgirl
Profile:  1984 31' Excella
otto , North Carolina
Bath tub area badly stained - suggestions?
Just bought 1981 excella II 31" and pulled it home today. Everything is pretty good with some minor fix ups except the bathtub area is badly stained with rusty rings. I hate that and want it to look nice. The material seems to be plastic. Can this be coated? Any good products or services that would fix this up?
jonesgirl is offline   Reply With Quote
Old 12-06-2007, 03:52 PM   #2
bake315
bake315's Avatar
Profile:  1994 34' Limited
Elgin , Texas
Images: 161
I wonder if brushing those areas with a little bit of naval jelly, then allowing them to sit a few minutes before rinsing would take care of it?
Cheers, Dave
"Finish."
AIR #4188
1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
bake315 is offline   Reply With Quote
Old 12-06-2007, 04:38 PM   #3
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
2 suggestions:
I'm not sure about 84 but the color in the 70s bathroom plastic was throughout the plastic and surface staining can be sanded off.
I painted my bathroom with an epoxy paint called Tough as Tile with excellent results. There are several different brands and you should find info on a search. If you go this route wear a respirator. Off gassing is more toxic than regular paint but not dangerous with proper precautions.
Hops make the hippy happy
Old 12-06-2007, 05:08 PM   #4
RBolton
RBolton's Avatar
Profile:  Belington , West Virginia
I'd start with an abrasive cleaner like comet. I was successful with an automotive finish rubbing compound and a whole lot of elbow grease. It seems like the rust stains permeate into the plastic and if they are not just on the surface - won't polish off - then refinishing may be the only solution.
RBolton is offline   Reply With Quote
Old 12-06-2007, 05:12 PM   #5
beckybillrae
beckybillrae's Avatar
Profile:  1986 31' Sovereign
Schererville , Indiana
The shower in my '86 was badly stained with a rusty color when I bought it too. I soaked the stains with Tilex soap scum remover and Clorox toilet bowl cleaner (the thick stuff). I put rags over the mixture & let it soak overnight. It really got alot of the stains out. I repeated the steps a number of times & only have one small stain (I think that stain really IS rust from a shaving cream can) that didn't come out. I think the other stains may have been less concentrated rust from hard water. The trick was to let it soak--just walk away! Good luck!
Becky
beckybillrae is online now   Reply With Quote
Old 12-06-2007, 05:16 PM   #6
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
I sanded with a very fine grit sand paper and it turned out good.
Other options;
1. You paint. Others have done this and have had good results.
2. Pay to have it professionally finished.
Garry
Old 12-06-2007, 06:08 PM   #7
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Oxalic acid will sometimes get rust stains out.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-06-2007, 06:32 PM   #8
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
Agree!
There is a cleanser called "Zud" that contains Oxalic acid - I once turned a completely rust colored toilet bowl pristine by simply sprinkling it in, dampening it and leaving it for 5 minutes.
I've seen several that were coated with "tough as tile" or similar products: they look great, and allow you to choose a whole new color palette for your bath.
Enjoy your Airstream, Paula
Today is a gift. That's why they call it "the present"
Old 12-06-2007, 06:44 PM   #9
CharlieE
Profile:  1990 34' Excella
Parsonsfield, , Maine
There is a product on the market called CLR. I think most of the Ace Hardware stores sell it. It removes calcium deposits, lime deposits and rust. It would seem to me if the tub plastic is porous enough to absorb rust then it would be porous enough to absorb the CLR. If you sandpaper or scour you may end up with"clean spots" where you sand unless you do the whole tub. Give CLR a try you might like it. Charlie E.
CharlieE is offline   Reply With Quote
Help! Fort Worth area service suggestions phoenix491 Brakes & Brake Controllers 6 12-04-2007 08:52 AM
Bath Tub Stained Really Bad Cleanable? lanajane Sinks, Showers & Toilets 2 04-30-2007 10:36 PM
"Must-Have" suggestions for potty area squrlgurl Waste Systems, Tanks & Totes 5 10-24-2005 09:13 AM
Campground suggestions needed- Orlando area Cedars On The Road... 1 02-08-2005 07:33 PM
Part needed badly for shower overlander76 General Interior Topics 3 06-10-2004 03:29 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
