Old 03-17-2014, 07:37 PM   #1
MyNancy1977's Avatar
Window tint bad
How can I clean tint out of windows, there peeling faded just bad white film build up...HELP
Sent from my SGH-T999 using Airstream Forums mobile app
ID:	207726   Click image for larger version
ID:	207728   Click image for larger version
MyNancy1977 is offline   Reply With Quote
Old 03-17-2014, 08:48 PM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
If it is window tint film:
Wait till a real hot day.
Use lots,of Windex and a razor blade.
Then scrub.
Windows should look like new.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-17-2014, 09:05 PM   #3
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
I took mine off with a heat gun and razor blade. I put the razor blade into a set of vise grips to be able to control it and get more leverage. Be careful with the heat gun though, you don't want to crisp up the window film, just get it hot. I kept the heat just in front of the razor blade. It took off most of the adhesive and then a little window cleaner cleaned up the rest of it.
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 03-17-2014, 11:02 PM   #4
Great but one thing it's between the windows double window!
Old 03-17-2014, 11:37 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The windows can be disassembled, cleaned and assembled. Zeppelinium has done a presentation of the process which was very informative. You could PM him and ask if he has detailed instructions for this.
Richard
Old 03-17-2014, 11:38 PM   #6
Mexray's Avatar
1978 28' Ambassador
Morada , California
All of us with the vintage 'dual pane' windows suffer from that inner film degradation...
There's much written about this subject here...do a search to find the threads...
It's a real time consuming, rivet bending task to take all the windows apart, clean and reconstruct...
I chose to install some heavy outside, static cling type window tint to cover em' up... It only lasts about a year or two, though...
I've thought of trying some perforated vinyl as used on vehicle wraps to stick on the outsides of the windows - maybe have it printed in an aluminum color to match the outside skin - kind of different...
Ray & Pat; Morada, CA
Old 03-18-2014, 07:37 AM   #7
Hmmm not baby idea
Old 03-18-2014, 09:13 AM   #8
1981 31' Excella II
New Market , Alabama
At some point they put real tinted windows in them. My 81 has the tinted ones. On the fixed windows you have to remove rivets and you need to know how to install new ones. On the windows that open the frame will split in two pieces held together with rivets. It is not and easy or fun process but it can be done.
Perry
Old 03-18-2014, 12:18 PM   #9
Seen video but I don't know whether to do it might do cling for now
Old 03-18-2014, 01:25 PM   #10
1981 31' Excella II
I don't recommend this but there are some who have busted the inner pane and scraped the tint off the window and put a shim in to hold the outer pane against the frame.
Perry
Best material to fix broken window pane Firstlight Windows & Screens 7 11-08-2011 01:01 PM
Safari 2005 Window Crank Failure neil.ervin Windows & Screens 3 10-24-2011 06:37 AM
How to replace a window?? UAPachyderm 2002 - 2005 International 11 10-14-2011 03:47 PM
"Wing" window 48tucker Windows & Screens 2 10-09-2011 09:13 PM
need window screens / metal fabrication in Austin, TX? bgordon Windows & Screens 2 03-31-2011 02:32 PM
