Old 11-30-2017, 07:32 PM   #1
Reeds Spring , Missouri
'77 Excella 500 wheel size and brake actuation
What is the bolt circle and offset on an original 1977 Excella 500's wheels? More importantly, will the wheels and tires from a 2017 Flying Cloud 27FB fit on the Excella, clearing its disc brake calipers? Both are 15" wheels with 6 lugs but am having trouble finding any more details.
Unfortunately, the trailer is a long way from us, but the person storing it for us reported that the brakes worked fine, despite the fact that the vacuum line was not connected. Can these trailers actuate their brakes with either vacuum or electric?
Connie M is offline   Reply With Quote
Old 12-03-2017, 01:19 AM   #2
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
The excella-vac vacuum hydraulic brake system can be retrofitted with a electric hydraulic actuator. I have a Carlisle 1600psi actuator that has worked well for several years. However, the calipers only fit with the original Alcoa aluminum wheels and won't fit with newer wheels.
4RXLA is offline   Reply With Quote
Awning size; wheel lug nut size jaygoree 2011 - 2015 International 0 02-19-2015 04:18 PM
1977 Excella 500 Coastal Camper :: 1977 Airstream Excella 500 Excella77 Airstream Registry Discussions 0 08-23-2014 02:18 PM
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 02:32 PM
