Old 09-20-2009, 05:25 PM   #29
1977 31' Excella 500
salem , Wisconsin
well she is gutted everything but the bathroom. I have alot of work to do but I am commited now. There are some bad outriggers for sure. Raining her and notice leaking around windows. Floor isnt to bad though. I am going to attempt to lift shell back inline one side at a time and repair outriggers one at a time from under trailer. Then put new axles in. Whats the best way to fix leaking around windows? Hard to see the issue from pictures but floor looks straight except outriggers.
ID:	87421   Click image for larger version
zacfrd is offline   Reply With Quote
Old 09-20-2009, 09:02 PM   #30
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
31 foot excella 500 problems
Leaks around windows can be the result of issues in several locations:
  • Window Seals . . . often need to be replaced to stop water inflitration.
  • Main Door Rubber Seal . . . this seal or gasket often needs to be replaced to stop the infiltration of moisture that causes soft spots in the floor either in front of or to the sides of the door.
  • Access Compartment Door Seal . . . another wear location that can be the source of water infiltration.
  • Caulking around exterior window frame where it meets skin. It may be necessary to remove remnants of old caulk and thoroughly clean surfaces before applying fresh caulk.
  • Other potential sources of water infiltration:
    • Awning Rail. The rivets used to attach the awning rail may have loosened up creating leak opportunities, the caulk bead may also need to be renewed.
    • Radio Antenna (if so equipped). The base gasket my be decomposing allowing moisture infiltration.
    • Rock Guard. The rivets that attach the rock guard hinge may have becom loose over time permitteing water infiltration. The caulk bead may also need to be renewed.
    • TV Antenna. Even though it is on the roof, its base seal can be the source of water infiltration that can find its way to a window frame where it appears as a leak.
    • Roof Vents. Again, even though they are on the roof, a leak in their gaskets can be a source of moisture infiltration that can make its way via a rib to appear as a leak at a window.
    • Air Conditioner. Another of the pesky roof penetrations where a gastket/seal can fail permitting wate infiltration that can appear as a leak elsewhere like a window frame.
    • Plumbing Vents found on roof are another source of water infiltration that can find its way via ribs to become a leak at a window.
    • Panel Seams. Exterior panel seams can also be a source of moisture infiltration. After cleaning any decayed existing sealant from seam (a sharpened popsicle stick or sometimes a tooth pick can be used to persuade the old sealant out of the seam).
    • Clearance and Running Lights. The bases on these lights can become loose allowing water infiltration . . . removing them, cleaning the ground and sealing with fresh caulk can cure a pesky leak that may show up at a window below or near light.
As with most leaks on an Airstream, one culprit cannot be condemned as moisture will follow ribs, wiring, etc. and may form a leak many feet from the actual source.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Noob looking at a 31' '77 AS 270win 1974 - 1979 Sovereign 61 03-23-2012 10:13 AM
Airstream 1973 Land Yacht Ambassador 29 Foot eBay Watch Airstreams on eBay 0 03-19-2012 12:50 AM
95 Airstream EXCELLA CLASSIC 29 FT TWIN BEDS NO RESERVE eBay Watch Airstreams on eBay 0 03-15-2012 08:20 PM
94 Airstream CLASSIC EXCELLA 30 FT SLEEPS 6 NEW TIRES eBay Watch Airstreams on eBay 0 03-15-2012 07:20 PM
2000 airstream excella 30' travel trailer no reserve!! Bank repo!! eBay Watch Airstreams on eBay 0 03-15-2012 06:20 PM
