Old 06-07-2012, 01:53 PM   #1
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Were is the Water Pump? 1969 Ambassador
I have looked all over my 29' Ambass but I cannot find the water pump. Does anyone know where it was originally?
Keith
Silverflames is offline   Reply With Quote
Old 06-07-2012, 02:27 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Locate the fresh water holding tank. Then follow the line, they are usually close to the tank, separated by a small inline filter screen.
I take it that the pump doesn't run. Otherwise you could turn it on and search for the source of the noise.
TG Twinkie is online now   Reply With Quote
Old 06-07-2012, 02:46 PM   #3
1969 29' Ambassador
The fill line was in the front, now MIA, there is a copper pipe that runs from the back under the road side cabinets, towards the section were the groucho was, but is capped off. I don't know if that was a water line or gas. My guess is that the pump was removed, but I just wanted to see were the factory put it.
Old 06-07-2012, 03:18 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
My '67 Globetrotter and a few Overlanders of similar vintage I'm familiar with had the pump next to the fresh water tank under the front couch. The water pipes do run inside down the street side to the rear "service center" and city water hookup.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 06-07-2012, 03:50 PM   #5
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
My 69 tradwind has the waterpump on the streetside under the gaucho. the water tank is under the gaucho as well. There should be a couple of holes on the streetside where the waterpump goes for draining the tank and the waterlines to winterize.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
1969 ambassador
