Old 07-13-2016, 02:38 PM   #57
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
Originally Posted by Hittenstiehl View Post
Looks like couch/convertible seating in front, side bench with long table as extra prep area and bedroom to the rear?
The dinette in the front converts into a Double size bed by removing the table and sliding the ottoman into the area where the table leg was.
The rear bedroom holds a "California Queen" (longer than a normal queen but same width) size bed wall to wall. The shower door doubles as a bedroom door when needed.
The area adjacent from the galley kitchen is a bench seat with a long oval table. The legs can be switched out and the table drops down to convert the bench into a Twin size bed. So it will sleep comfortably 5 adults. Or in our case 2 adults and two kids.
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Old 07-13-2016, 02:40 PM   #58
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
Picture #8 with the mountains on top. Airstream should put that in a calendar.
That was the Tetons
Artisan Airstreams
Old 07-13-2016, 02:55 PM   #59
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
Here are some more!
If you are liking what you see, please don't forget to rate this thread
Thanks!
ID:	266688   Click image for larger version
ID:	266690   Click image for larger version
ID:	266692   Click image for larger version
ID:	266694   Click image for larger version
ID:	266696   Click image for larger version
Artisan Airstreams
Old 07-13-2016, 03:15 PM   #60
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
And more....
ID:	266698   Click image for larger version
ID:	266700   Click image for larger version
ID:	266707   Click image for larger version
ID:	266709   Click image for larger version
ID:	266711   Click image for larger version
Artisan Airstreams
Old 07-13-2016, 03:32 PM   #61
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Looks like maybe you could do the calendar. Beautiful shots.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-13-2016, 05:11 PM   #62
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
Looks like a fabulous trip! Wonderful photos! Makes me yearn for the road...
duncans is offline   Reply With Quote
Old 08-03-2016, 07:11 AM   #63
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
This trailer is now for rent!
See the link for details
https://www.outdoorsy.co/rentals/4660
Artisan Airstreams
Old 08-03-2016, 08:52 PM   #64
1977 31' Sovereign
Sunset Valley , Texas
Congratulations!
That was an inspiring read. You certainly did some amazing work. I'm proud FOR you.
A giant thank you for taking the time to share your progress, while most/many of us could only hope to aspire to the level of care you put into this AS, it at least gives me courage to know I'm not an insane person while plugging away at 2am fiddling with this or that... Or maybe that's what it takes. Who cares.
Thank you again,
Ian
Iansk is offline   Reply With Quote
Old 08-07-2016, 07:12 AM   #65
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Times two
Old 08-20-2016, 10:03 AM   #66
ArtisanAir's Avatar
1967 28' Ambassador
1960 24' Tradewind
Edgewood , Kentucky
Airforum Appraisal
For the life of me I cannot find a appraiser in my area to help me out.
If anyone knows of a appraiser in the Cincinnati area please let me know.
But since I cannot get any answers I would like for the airforum community to give their opinions on a appraisal price, just for fun. Curiosity more than anything. Be honest, my feeling wont be hurt! I need to try and value/grade my work.
This is the most knowledgeable group so your feedback matters!
Thanks in advance!
Artisan Airstreams
Old 05-14-2017, 09:56 PM   #67
Plattsmouth , Nebraska
Originally Posted by ArtisanAir View Post
I removed the old exterior parking lights and buffed the spot before installing the new light. I finished replacing the exterior parking lights with a LED equivalent and sealed them on the back side to the trailer along with 3/16 rivets. once the LP and water lines were ran, I capped them off and pressure tested (50 psi) both systems for leaks. Then started the skinning process.... I chose the 4' x 8' sheets of red oak paneling for the walls and 3003 H4 aluminum .040 thickness for the ceiling. On the end caps I decided to go aluminum. This is a challenge due to not having any template to go by. I tried using an English wheel and some rather large pieces of aluminum. After an hour or so, it was back to the drawing board. I called my metal supplier and had them shear 8" strips so I could fillet the end caps into 17 pieces. It was critical to have these pieces sheared for the factory edge quality due to the edge puckering that occurs when you cut them by hand ,even with electric snips. I simply freelanced the entire cap making sure that all steps and rivets were incremental. When doing this you must concentrate and take your time. Measuring in a lot of different places will ensure your pattern is consistent. Clecos are a must with this project and in my mind you can never have too many. I used 4' x 10' aluminum panels for the ceiling which I had to have help wrestling the piece against the ceiling to rivet in place, while also cutting out for all necessary vents and lights.
Did you do anything to the ceiling and endcaps after you installed all the aluminum? What do you do to avoid scratches etc? I'm was going to install all new interior panels but figured it would get pretty scratched up during the install so I was just going to paint everything.
Jhiner1978 is offline   Reply With Quote
Old 06-12-2017, 06:56 PM   #68
How did you keep from scratching the aluminum? How were you going to finish the aluminum once done?
ambassador, rebuild, remodel, renovation
Toilet or Not? 67 Ambassador Remodel ArtisanAir Waste Systems, Tanks & Totes 47 05-19-2015 09:20 PM
Skin choice 67 Ambassador remodel ArtisanAir Upholstery, Blinds, Walls & Interior Finishes 0 05-17-2015 10:19 AM
Remodel of my '68 Ambassador. purman 1966 - 1969 Ambassador 100 03-10-2012 07:32 AM
AIRSTREAM 1967 Airstream Ambassador 28 ft GUTTED! Ready for your remodel!! eBay Watch Airstreams on eBay 0 10-21-2011 07:00 PM
fuel gauge showing full when it is not full Normin storm Mechanics Corner - Engines, Transmission & More... 2 08-25-2009 10:31 AM
