Old 02-08-2013, 05:45 PM   #1
1968 28' Ambassador
Shreveport , Louisiana
Sewage tank capacity?
Does anyone know the sewerage tank capacity in a 1968 Ambassador?
Headhog is offline   Reply With Quote
Old 02-08-2013, 05:49 PM   #2
1986 31' Sovereign
Miami , Florida
16 gallons or so.
Mike
Old 02-08-2013, 08:58 PM   #3
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
If your 68 is same as my 69 it's small. Once you pull the belly pan there is room for a much larger tank. I put a 27 gal black tank in mine. Just make sure u pull it dry. Many folks believe having the weight in the holding tank can lead to rear end separation.
ID:	178577   Click image for larger version
Silverflames is offline   Reply With Quote
Old 02-09-2013, 08:17 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Not being familiar with your specific trailer. Is your current BW tank above or below the floor? If it is above, it will be in the 12 gallon range.
Just out of curiosity. Why the need for such a large BW tank? I would think that installing a larger Grey Water tank would be the ticket, since showers, dishes and so forth require much more water.
TG Twinkie is online now   Reply With Quote
Old 02-09-2013, 11:47 AM   #5
1969 29' Ambassador
The 69 ambassador came with just one tank, and it was in pretty bad shape. I had the space under the floor so I figured better to have more volume than less. 30 gal fresh water, 27 gal black and grey. Less likely to overflow a tank...
Grey tank for rear bath '66 TW. FreshAir Waste Systems, Tanks & Totes 15 02-13-2012 09:06 PM
Gray Water Tank Flush Road Geezer Waste Systems, Tanks & Totes 6 02-01-2012 06:23 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 08:19 PM
Sewage in Belly - EW! godaddy64 Waste Systems, Tanks & Totes 16 04-19-2011 11:11 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
