07-08-2012, 11:40 PM
#81
1963 22' Safari
2020 27' Globetrotter
State of
Man that sucks! May things get better fast. On a side note, amazing looking woodwork going on in there!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
07-09-2012, 12:32 AM
#82
Salem
, Oregon
Hi, sure glad that didn't happen inside of your trailer.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
07-09-2012, 06:03 AM
#83
1968 28' Ambassador
Cedaredge
Originally Posted by Diesel1
LOL.......sorry..........
Yeah, I had to laugh about a minute after the shock and foul langue wore off. I kind of chuckle every time I walk in there. can't do much for cleaning up. Thought I might just finish painting that little red compressor black though
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-09-2012, 07:08 AM
#84
1967 22' Safari
1978 25' Tradewind
NEW LENOX
Jason,
Can you describe the 'spin weld' techinique you used to weld the fittings to your tanks? I thought special tools were required.
Thanks, John H
07-09-2012, 08:21 AM
#85
1967 22' Safari
1978 25' Tradewind
NEW LENOX
Jason, sorry for my earlier dumb question. I just re-read your posts and looked a little closer at your pictures.... Using a hole saw to hold the fitting is a great idea.
Thanks, John H
07-09-2012, 09:25 AM
#86
1971 21' Globetrotter
Arvada
I lost a gallon can of epoxy primer off our paint shaker at work a few years ago, had to clean it up as it would take years to dry without the hardener in it. There are stains to this day on the hanger insulation and floor. At least I was standing away from it and was out of the explosion zone.
07-09-2012, 09:27 AM
#87
Jupiter
DIY fitting spin... If it was me it would have been just an excuse to get that Greenlee $95 carbide toothed hole saw and $65 mandrel
purman - I hate to should on others, but you should be counting your blessings now and give a little gift to the Angel on you shoulder that nothing electrical was 'cycling' to act as a sparkplug for that 12-ounce charge of fuel! Can we say "spray-paint flamethrower"??
What I don't see is the outline of your body on the wall, that'd be a nice picture
Maybe don't let your vices become habits? (Nice vice by the way)
I see a gallon of something on the floor beneath the vice... Last time I was using the shop vice & a HS cutoff tool I glanced down to see the three gallons of MEK I snagged for 25¢ a gallon at ACE hardware (when their muriatic acid seeped & flash rusted all the nearby solvent cans) being painted with showers of sparks. So forever on paint/solvents don't get stored near the bench/vice; its an apples and oranges thing, apples with apples and oranges with oranges, firebombs with firebombs?
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
07-10-2012, 08:45 AM
#88
1968 28' Ambassador
Cedaredge
I just about have everything made in the trailer now. I just need the get the couches that convert to bunks done. They are about half built. Then it's just a matter of some trim and cabinet doors. Hope to start staining and finishing friday.
It was a long weekend and long hours. Sanding seems to take the longest.
We are putting a perminat bed in the front You can see in the pictures the curved wall. I put this in so when the door is open you aren't looking straight into the bed . It seems like it will work well. once I get it stained I can get the oven, range, and fridge back in.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-10-2012, 01:15 PM
#89
Salem
, Oregon
Hi, the curved wall is a unique idea; I like it. You are going so fast and doing such a great job.
07-11-2012, 08:05 AM
#90
1968 28' Ambassador
Cedaredge
So, working on the couch / bunks. Got the bases built and now working on the backs. I had this aluminum frame that went on a camper top to lift a boat up on it. Got it at an auction for $15 thinking I could use the aluminum one day. Well today was that day.
I used the C-channle from it to run the length of the bunk. This will give it more than enough support when it is turn up to form a bunk. I also ran a piano hinge along the back. I need to get some square tubing today to build the flip down arms that will support the bunk once it is up. Should be able to even hold me
Also another pic of the front where the bed is going. I built this wall to block the view of the bed when the door is open, and it works great.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-11-2012, 09:54 AM
#91
bilby05
1962 24' Tradewind
1962 24' Tradewind
Canyon
Thanks for posting all of the pics gives me ideas for our 62 Tradewind.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
07-11-2012, 09:55 PM
#92
1968 28' Ambassador
Cedaredge
Ok I got the bunks done today. Just a few things to wrap up tomorrow then I can stain and finish the inside. You can see from the pics I added wood to the bunks then screw it to the side of the airstream.
I have some legs I made out of steal and will take pics of those once the paint dries and I get them on. Hey will fold up when in couch mode The bunk / couch works great. I even hopped on them and bounced around and they are solid. I weigh about 205.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-11-2012, 11:20 PM
#93
1967 24' Tradewind
Wickenburg
Quite the crafty lad are you! Lookin good!!!
Fortune cookie say....."Prudence keeps life safe, but does not often make it happy."
07-12-2012, 10:23 AM
#94
Ottawa
, ON
Clever design, I like it!
What do you think the top bunk would hold. I`m thinking of when our son and daughter us the trailer, it would make more sense to put the toddler in the bottom and daddy up top.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
07-12-2012, 10:35 AM
#95
1968 28' Ambassador
Cedaredge
Well it held me and I'm 205 so I figure it should go a few more pounds.
Yep the twins will be on the bottom and my 6 and 9 year olds will take the top bunks.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-12-2012, 11:24 AM
#96
bilby05
1962 24' Tradewind
1962 24' Tradewind
Canyon
Have you considered writing a book? Oh wait, you just did, in electronic form. Way to go. cheers, bill b.
07-12-2012, 09:06 PM
#97
1968 28' Ambassador
Cedaredge
Got the build out done today. Just a few little bits of trim on the wall to put in tomorrow. I decided to use Minwax waterbase finish. It dries quick and doesn't stink. It brings out the birch and Aspen colors very nicely. It also darkens up the wood too. Started to put some on tonight but it got dark on me. I will have to put two coats on, but I think it will look nice when done.
Here is a pic of the legs for the bunks. I welded a hinge to the leg and a flat piece of iron to give it strength. I drilled four holes in them tonight and will bolt them on to the plywood tomorrow. I also put rubber stoppers on the bottom so they don't dig in the plywood. I think I will put a little lip of wood down so they can't fold up if pushed on. Don't want the bunk falling with someone on it or underneath it.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
07-12-2012, 09:46 PM
#98
Jupiter
I'm in serious like with your 'ying yang - loutus-flower" curved windscreen wall idea, though looking twice it seemed to be designed as a defensive position to better greet intruders coming through the door...
07-12-2012, 10:59 PM
#99
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
You have done some marvelous work at a dizzying pace. My compliments to you.
Dan
07-12-2012, 11:10 PM
#100
1968 28' Ambassador
Cedaredge
I figure I can put Kevlar on the back side and put some gun ports in it . Just wanted to block the front bed when the door is opened in the morning, or afternoon nap time .
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
