Old 06-07-2009, 09:28 PM   #57
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Nice work Jason, its really coming along nicely, like the light wood floor. That and the white bathroom fixtures will look really clean.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 06-07-2009, 09:38 PM   #58
1964 30' Sovereign
Elephant Butte , New Mexico
You have done a marvelous job. Kudos. Talk about "sweat equity" !
jhohnke is offline   Reply With Quote
Old 06-08-2009, 07:34 AM   #59
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
What type of water heater are you using, and why? Thanks, adios, John
Diesel1 is offline   Reply With Quote
Old 06-08-2009, 07:42 AM   #60
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
It's just a plain atwood water heater. You have to light it from the outside. Main reason it is the same size as the old one and I can use the original aluminum cover not the white one it came with. I guess I could of upgraded to a auto light, but we don't use it two much so going out to light it is no big deal, plus it was a little cheaper that way.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-08-2009, 12:17 PM   #61
Diesel1's Avatar
1967 24' Tradewind
Thanks, That is my plan. I don't want an auto light, they seem to need 12v to light. I a big believer in the KISS principle. It is good to know that I can use the original cover. Adios, John
Old 06-08-2009, 02:31 PM   #62
SuzynBobby's Avatar
1970 29' Ambassador
Interlachen , Florida
Did you resolve the dining table up front issue? I saw a pic on this site today of a "Planet" Air (AS). He used a wall mounted swivel swing-away hardware with a narrow table on it. I'm impressed with your AS remodel. What did you do with the water line that goes from the kitchen to the bath? On my '70 Ambassador it runs under the goucho (where you now have the side dining. But it seems your tub may be on the street side and mine is on the curb side. Guess if I want to do something different with that area I must move the pipe.
SuzynBobby is offline   Reply With Quote
Old 06-09-2009, 08:42 AM   #63
purman's Avatar
1968 28' Ambassador
Well, no that I have the dinette in the middle I just going with an L shaped couch and take the old table hardware, cut it down and make a small flip up table buy the door. That way we can eat up there or play games etc.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-11-2009, 09:13 PM   #64
purman's Avatar
1968 28' Ambassador
Working on the New black tank I got from Inland RV.
It has a flange around the top. So I have decided to drill holes every 4 inches and screw it to the subfloor from underneath. Then run 2 support straps as well. Then install the new pan I made. The old one was rusted out and I'm can't believe I didn't drop the tank when it was full!!!!!!!
The new pan will support it like the old one did. So I'm pretty sure this thing is going to be solid. I'll take pics tomorrow of my progress.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-12-2009, 08:29 PM   #65
purman's Avatar
1968 28' Ambassador
Well, today was a very broken up work day so I didn't get what I wanted done.
But here some pics of the bathroom and what tile I'm am using for the counter top. Tomorrow I hope to get all the wall panels cut out and put in and box in the cabinets...
I got the holes cut out for the toilet and vent for the black tank. And marked on the black tank. I need to got down to the local rv guy and get a new toilet flange to mount the toilet on with.
And I also need to pick up a fiberglass kit to put the flanges on the new black tank...
I have 3 good longs days of work coming up.
ID:	82191   Click image for larger version
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-12-2009, 09:32 PM   #66
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
Where did you get the tub and wall panel for above the sink? Are they from the newer model AS? They look custom due to the curves. Just curious
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 06-12-2009, 09:41 PM   #67
purman's Avatar
1968 28' Ambassador
Original stuff that came with it. I just got a kit to paint the tub/shower and some spray paint for plastic for the wall unit.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-14-2009, 08:59 PM   #68
purman's Avatar
1968 28' Ambassador
Ok, Got the bathroom walls up today, pocket door, and all the parts for the closet cut and stained. They go in tomorrow. Also Get the the last wall section up buy the fridge and get it in place...
Man tracing those old wall peaces doesn't mean they are going to fit...
ID:	82328   Click image for larger version
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-15-2009, 09:35 PM   #69
purman's Avatar
1968 28' Ambassador
Well I got the closets in, the fridge in place and the frame for the front "L" shaped couch in. Lot of work building from scratch. Plus I designed as I went. Not always the best way to do things.
I have roped my neighbor into doing some small stuff like putting in lights and the new batter box. He will help tomorrow. It will save me some time. He has been putting the new fitting in the black tank I got from Andy.
I will try to post pics tomorrow... 4 more days, then I'm suppose to be on the road.... We will see....
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 06-16-2009, 12:45 AM   #70
Aluminum in 3-D
Blue Pearl's Avatar
1968 28' Ambassador
Seaside , Oregon
I'm excited to see pictures of the L-shaped sofa frame, we are doing the same on our 68 Ambassador. I'm going with a stand alone table that can be taken outside and used with a couple of vintage camping chairs.
Teresa
Membership chair
Wally Byam Airstream Club
Past President Oregon Unit 090
Campfires, the original social media!
wbcci#29827
Check out the [URL="https://airstreamclub.org/"and Wally Byam Airstream Club on facebook
Blue Pearl is offline   Reply With Quote
1968 ambassador
2001 LandYacht remodel 01 LandYacht Land Yacht/Legacy Motorhomes 29 03-21-2018 11:05 AM
Photos of Safari 1954 restoration safari 1954 1954 Safari 81 08-14-2012 06:01 PM
Really horrible feeling in my stomach Mrs.Mod General Interior Topics 23 04-08-2012 11:30 AM
Can I charge my drained interstate batteries? bonginator Winterizing, Storage, Carports & Covers 17 04-01-2012 08:16 AM
Limits of cold weather Boondocking handn Boondocking 17 03-25-2012 11:05 PM
