Old 05-31-2014, 07:36 AM   #29
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
No I don't we have a caravel and the heater is not efficient at all and posses more of a fire hazard then a benefit not only that but we are more about using the gas for cooking hot water and the fridge! Your heater after clean up is more practical anyway due to larger trailer and bigger black tank to keep from freezing!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 05-31-2014, 07:42 AM   #30
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
New to me '67 Ambassador
It isn't really a space heater but a 14,000 btu direct vent wall furnace.
It easily heats my 31 footer, even when it is cold. It has been tested to 9 degrees so far.
Old 05-31-2014, 11:16 AM   #31
streamslave's Avatar
1967 28' Ambassador
Gatlinburg , Tennessee
Thank you Mimi yours is identical to mine.
streamslave is offline   Reply With Quote
Old 05-31-2014, 03:25 PM   #32
1967 28' Ambassador
I too should buy a couple of carbon monoxide detectors.
I also should just bite the bullitt & buy a new furnace I guess
Old 06-11-2014, 02:33 PM   #33
1967 28' Ambassador
Name:	ImageUploadedByAirstream Forums1402518724.898602.jpg
I have removed the black tank and it seems as though the floor is a bit rotten because the rear compartment door had been missing for Lord knows how long here's a pic of the carnage
Old 07-05-2014, 03:28 PM   #34
1967 28' Ambassador
Name:	ImageUploadedByAirstream Forums1404595630.757041.jpg
Does anyone know if there's a similar carpet out there for purchase?
Old 08-27-2014, 03:39 PM   #35
1967 28' Ambassador
Here's a few pics of my problems. I could use some direction with my water heater surround, it looks awful. I think if I had an aluminum piece to replace the sheet metal with id be satisfied. Also, the air conditioner surround needs some love. When I removed the surround, I found the inner unit to have what looks like black tar sealing it to the aluminum roof.
Thank you in advance for any help or insight to this.
Name:	ImageUploadedByAirstream Forums1409175416.746707.jpg
ID:	220020Click image for larger version
Name:	ImageUploadedByAirstream Forums1409175446.699490.jpg
ID:	220021Click image for larger version
Name:	ImageUploadedByAirstream Forums1409175466.845937.jpg
ID:	220022Click image for larger version
Name:	ImageUploadedByAirstream Forums1409175486.455825.jpg
ID:	220023Click image for larger version
Name:	ImageUploadedByAirstream Forums1409175505.054570.jpg
ID:	220024Click image for larger version
Name:	ImageUploadedByAirstream Forums1409175522.214812.jpg
ID:	220025Click image for larger version
Name:	ImageUploadedByAirstream Forums1409175556.431946.jpg
It's looking better every day!
Old 08-27-2014, 04:10 PM   #36
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
A/C Shroud
You can buy a new Shroud from a few vendors.... Mine came from InlandRV.com. There are other vendors that carry replacements for that shroud. Do a search using keywords like A/C Shroud, Armstrong Air Conditioner, ETC. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 08-27-2014, 07:08 PM   #37
1967 28' Ambassador
Thank you Ed! I'll check with Inland.
Old 08-28-2014, 10:16 PM   #38
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
carpet
Look to local carpet stores. You might even find a very close version of that same sample you show in your previous post. Lots of colors of that style of low pile carpets are still available. Ed
Old 09-03-2014, 12:27 PM   #39
1967 28' Ambassador
Thank you Ed.
I have a factory installed wire approximately 8" to the right of the water heater... Can someone please tell me where it goes? Everything works now even though it doesn't go to anything & it's been just hanging there since I bought the trailer.
Thank you!Click image for larger version
Name:	ImageUploadedByAirstream Forums1409768807.609357.jpg
Old 09-03-2014, 09:25 PM   #40
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Wire
Check the stubbed wire for 12 Volts DC and 110 Volts AC. Also check to see if you have an exterior outlet directly above that wire on the exterior skin. If so is it live when the trailer is plugged into shore power? If not it could be a PO cut the AC wire inside to disable a defective outlet that was causing the skin to shock them when hooked up to shore power. If so the only option is to leave it dead or remove the inner skin to replace the wire and check for any shorting inside the shell. These trailers had aluminum wiring and were subject to poor connections and shorting over time. Ed
Old 10-13-2014, 04:20 PM   #41
1967 28' Ambassador
It's coming together pretty good.
A big thanks to Randy at Bestconverters.com & Inlandrv Click image for larger version
Name:	ImageUploadedByAirstream Forums1413238768.099629.jpg
ID:	224330Click image for larger version
Name:	ImageUploadedByAirstream Forums1413238779.269080.jpg
ID:	224331Click image for larger version
Name:	ImageUploadedByAirstream Forums1413238788.593393.jpg
ID:	224332Click image for larger version
Name:	ImageUploadedByAirstream Forums1413238799.792127.jpg
ID:	224333Click image for larger version
Name:	ImageUploadedByAirstream Forums1413238811.280455.jpg
Old 10-13-2014, 04:53 PM   #42
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
wow you already polished it? Great looking trailer...enjoy it ..maybe you can make it down to one of our Georgia Airsteam Rallys,,we have one coming up but it is pretty well booked up...Check the threads for Falluminum and Springstream..
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Ambassador Kinton :: 1965 Airstream Ambassador International sckinton Airstream Registry Discussions 0 08-17-2013 01:17 PM
1972 Airstream International Land Yacht Ambassador :: 1972 Airstream Ambassador airpatton Airstream Registry Discussions 0 03-22-2012 12:01 PM
Ambassador :: 1971 Airstream Ambassador nascar427 Airstream Registry Discussions 0 08-19-2011 10:07 PM
New member - new 1968 Ambassador jnjmiller 1966 - 1969 Ambassador 7 01-30-2007 06:54 AM
New Custom Tank for 1962 Ambassador Lookinghard Waste Systems, Tanks & Totes 6 09-28-2005 05:35 PM
