Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Ambassador > 1966 - 1969 Ambassador
Old 09-09-2015, 06:02 PM   #1
Farmingville , New York
Need Help Please!!
I am restoring my 67 Ambassador and I bought it semi gutted. Well I am trying to find light fixtures, outlet boxes, and street side access panel 22x11 Does anyone have anything they are looking to sell or have any leads? Any info would be greatly appreciated. Thank you
Mike91180 is offline   Reply With Quote
Old 09-09-2015, 08:13 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Some will post soon.. I can't help, sorry..
However, here is a link I have used:
Vintage Trailer Supply | Parts for 1940s-1970s Travel Trailers
good luck!
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-10-2015, 05:31 AM   #3
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
I don't recall a street side access that is 22 x 11 on a 67. Was it a twin? Do you have any pics of the door location. Unfortunately I also purchased a gutted 67 so I do not have any fixtures of any sort. I do however have the furnace and water heater if needed..
I will say, it is not the end of the world. I successfully created an access door for my pullout grill project. It wasn't easy, but it can be done. I bought the aluminum extrusions for the frame of the door from Vintage Trailer Supply Hingeless Baggage Door Frame Extrusion. Then had some aluminum sheeting cut to the correct size and assembled with a foam core. It was then MIG welded in the corners for integrity. You can decide then to install a cabinet lock or not. I hope this helps you in your troubles. Good luck!
ID:	247756   Click image for larger version
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Old 06-20-2016, 05:46 PM   #4
1967 28' Ambassador
Center Moriches , New York
Hi did you ever get your door? Mine was missing a compartment door also. I purchased one from airstreamsupply.com its called a access compartment door.
MaggieO is offline   Reply With Quote
Please help - opinion please - 1967 caravel for $1000 knishiya Airstream Trailer Forums 5 05-11-2012 09:33 PM
New and need help. Please! 72airstream Electrical - Systems, Generators, Batteries & Solar 4 05-28-2006 03:42 PM
Need Help Choosing Trailer Please! tallone Member Introductions 22 01-23-2006 08:54 PM
Need Photo Help Please!! KY Girl Forum Admin, News and Member Account Info 9 05-03-2005 01:07 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
