Old 08-16-2012, 09:20 PM   #1
Benton , Arkansas
My first Airstream
I'm picking this camper up this weekend. From looking at the archived pictures, I think it is a 1968 28' Ambassador International. Have I identified this camper accurately? Thanks four everyone's help.
ID:	166028   Click image for larger version
SIMPLEMAN is offline   Reply With Quote
Old 08-16-2012, 09:27 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Yep, Looks just like mine. Welcome to the forums and ask lots of questions..Here is what I had to do with mine. I hope yours is in a little better shape. Looks like they may have move stuff around. the Water heater is further back where your patch is..
the first time:
http://www.airforums.com/forums/f174...dor-44644.html
The second time, still ongoing:
http://www.airforums.com/forums/f174...8-a-90934.html
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 08-16-2012, 09:32 PM   #3
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Welcome to the forums and congrats on your new Airstream.
All 66-68 Airstreams have curved windows that match the curvature of the body. If you can take a close look at the windows especially when they are open, that will help to identify the year.
Dan
Old 08-19-2012, 08:59 PM   #4
Benton , Arkansas
Well, I was wrong. Turns out the camper was a 26' Overlander. It does have the curved glass, so I'm thinking it's a 67,68,or 69. The plate with the serial number is missing, and no number/letters on the a frame either.
Old 11-21-2012, 08:23 PM   #5
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
The plate with the vin number is the red and blue plate right next to the door under the window. It's the center section, if you clean it good you should be able to read the numbers. I had to run black grease over mine and then wipe it off. This left the black grease it the numbering, but not on the plate. I need the contrast to see the well.
Silverflames is offline   Reply With Quote
Old 11-21-2012, 08:58 PM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
What numbers appear on the tittle? That should tell us what it is.
Old 11-22-2012, 04:13 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard....
If you need help finding the "tittle".....PM me.
BTW congrat's on the AS.
Old 11-22-2012, 05:04 AM   #8
1993 30' Excella
1969 27' Overlander
Wauseon , Ohio
It's not a 69! A 69 has round corners on the rear window.
Bill
William K is offline   Reply With Quote
Old 11-23-2012, 04:38 AM   #9
Benton , Arkansas
No title and the plate is missing. It's a 68, since the windows have the aluminum around their edges. At least that's what I have read.
Old 11-23-2012, 08:48 AM   #10
Bill
Bill
Sorry, but a 69 Airstream has the same window in the rear as in the front, which has square corners.
66, 67 and 68 Airstream used square cornered windows in the front and rear.
The 1970 models went to round corners on the rear, except when the rear also has the wrap windows, and then and only then does the rear window have square corners.
Old 11-23-2012, 08:52 AM   #11
Correct.
Check it for rear end separation.
Also, from your photo, it appears that maybe the rubber rods in the axles are history.
Old 11-24-2012, 10:29 PM   #12
1969 29' Ambassador
No title and the Vin Plate is missing? That would make me very nervous...
Old 11-25-2012, 12:43 PM   #13
Benton , Arkansas
All I'm going to do with the camper is rewire it, replace the flooring, and put bunk beds in it for deer camp. It's gotta make it 47 miles down the road and it will be home!
