Old 01-20-2014, 09:36 PM   #1
1968 28' Ambassador
Orlando , Florida
Full renovation starting on 1969 Ambassador
Well I made the totally impulse and not-well-planned out decision to buy an airstream on Craigslist that is in need of a total tear down renovation. I've done a little bit of work now where I feel comfortable enough that I'm not just gonna turn around and sell it, so I figured I'd share the progress here.
Airstream Adventures
Every step of renovation I am learning from this site, so I hope I can add a few tips of my own by the time I get done.
OrlandoNewb is offline   Reply With Quote
Old 01-20-2014, 10:11 PM   #2
1968 28' Ambassador
Orlando , Florida
Attached are some of the images so you don't have to jump out to the tumblr to take a look.
ID:	204077   Click image for larger version
ID:	204079   Click image for larger version
Old 01-21-2014, 11:57 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You might want to try a more surgical approach to your renovation. Those interior skins that you are ripping out can be reused or at least used as templates for new ones. The interior skins are a part of the structural strength of an Airstream so they will have to go back in. Aluminum sheet is expensive so you might want to take that into consideration.
Old 01-21-2014, 12:21 PM   #4
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Before you destroy the whole trailer over a few beers, you might want to do some research into how they are built & why they are built that way. There is a ton of information located here on the Forums & on The Vintage Airstream Podcast | Vintage Trailer Restoration . There is also a large show/rally (alumaflamingo) that'll be going on in Sarasota, 18-24th of February that'll have an open house, a vintage area, & seminars about Airstream construction. All of these things will help you avoid costly mistakes.
Colin
Colin H is offline   Reply With Quote
Old 01-21-2014, 12:35 PM   #5
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Congrats on the I see your gonna need new strapping under the frame. Had the same problem with my Safari. Rusted and thin.
My " add a step' is attached there so I went a gauge thicker. Didn't want to loose the step in transit. Something to consider if you have the same. As Aerowood said. The surgical approach might be the best way to go.One section at a time.
Sent from my LG-E617G using Airstream Forums mobile app
Cyquest is offline   Reply With Quote
