Old 08-08-2010, 08:42 AM   #1
1969 29' Ambassador
Tahoe City , California
Dimensions of the floor plan 1969 Ambassador
I just bought a 1969 Ambassador and have replaced the front 8 ft of floor. I have a few questions. 1) I was not able to get the floor completely under the aluminum footers. Is this going to be a problem? 2) I had to split the floor boards over half the cross beams and I am looking for ideas on how to secure the floor board to the cross beams. I really do not want to remove the under panels since they are in good shape and I don't have a good way to work under the trailer. 3) Are there any techical drawings of the front end (tapers and radius)?
Thanks Rob
robbarley is offline   Reply With Quote
Old 01-04-2011, 03:40 PM   #2
Ilfracombe , North Devon England
im replacing the front right hand corner on my As what dimensions do you want ?
will have a measure up before i put the floor back down.
im going to take the belly pan off to bolt the floor back down.
could you weld nuts under the chassis and then bolt it down that way ?
you will have to make sure the bolts are counter sunk in the middle of the floor, but not to worry on the outer edge as the seating will be there.
2lrminivan is offline   Reply With Quote
1969 ambassador
Floor plan RankAm General Interior Topics 11 03-03-2009 03:16 PM
What's your floor plan? SafeHarbor 1978- 1979 Excella 500 51 06-28-2007 12:31 PM
Best Floor Plan and Why JimGolden Interior Restoration Forum 13 01-14-2006 08:34 PM
Floor dimensions needed uwe Repairing/Replacing Floor &/or Frame 4 08-15-2004 06:26 AM
Floor Plan upallnight Our Community 3 04-22-2004 12:22 AM
