Old 06-08-2014, 10:24 AM   #1
RKL1954's Avatar
2015 25' FB Flying Cloud
1966 28' Ambassador
Vancouver , Washington
Any idea what went here? 1966 Ambassador
We just acquired a 1966 Ambassador. Mostly original. Any idea what went here? The empty space at the top. It's in the "kitchen" next to the sliding doors above the counter.
RKL1954 is offline   Reply With Quote
Old 06-08-2014, 10:25 AM   #2
Gainesville , Florida
No picture, jim
avionstream is offline   Reply With Quote
Old 06-08-2014, 12:03 PM   #3
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
In our '66 Safari, there's a similar panel above the fridge. 110 volt outlet, water pump switch, and a 12 volt outlet (to receive a plug that would fit a car's cigarette lighter or 12v power outlet in newer vehicles).
Yours looks about the same, except for the white square above the 12v outlet. Is that velcro, or is it a cutout where something was once mounted in the wall?
Old 06-08-2014, 01:14 PM   #4
2002 19' Bambi
Lafayette , California
It definitely looks like a cutout with a couple of screw holes or screws on either side. The surrounding wood has not been bleached through exposure to light, so whatever was mounted there extended considerably beyond the cutout.
So, do I have any idea what it could have been? No
Tim
Tim A. is offline   Reply With Quote
Old 06-08-2014, 11:41 PM   #5
RKL1954's Avatar
1966 28' Ambassador
Yes - it's a cut out. The white is the back wall of the cabinet behind the wood paneling.
Old 06-09-2014, 05:26 AM   #6
Baltimore , Maryland
You have a shadow. That is all. Nothing missing. There is a Tv antenna plug below too?
Old 06-10-2014, 08:43 AM   #7
RKL1954's Avatar
1966 28' Ambassador
I think 62overlander has the answer. There's an old TV cable behind the panel that's not attached to anything. The hole most likely had some sort of plug to plug the antenna into a TV.
Interestingly, there's a rats nest of wires behind the panel. One is marked "AC" but ends cut off with the wires exposed! Clearly electrical codes have changed since 1966!
Rasjad
1966, 1966 ambassador
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 09:40 PM
Any idea what we have here? RichardT Our Community 2 02-06-2008 11:41 PM
It is here! Well, almost here... 1973 Ambassador Pschoerrn 1970 -1973 Ambassador 10 05-20-2005 03:56 PM
OK, here's another lame idea... drboyd Axles 27 07-07-2003 10:15 AM
