Old 06-14-2005, 06:09 PM   #43
till's Avatar
Lisle , Illinois
Images: 108
Well I just sent off a couple of winders (from the parts trailer) to Eljay today.
I managed to remove most of the wiring today. That really seemed to open up the coach quite a bit. I guess I could always Ebay the old wire for the resotration nuts out there. Mmmm One box of vintage Original copper and aluminum wiring form a California built 1967 Ambassador International double. Opening bid, $???.00 for those that have to have OEM or nothing at all for the restoration of there coach.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 06-14-2005, 06:49 PM   #44
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
hey tedd, folks have ebayed broken toilets, i say go for it!
john
you call them ferrets, i call them weasels.
Old 08-19-2005, 06:21 AM   #45
till's Avatar
Lisle , Illinois
Images: 108
Just an update for those that may be wondering what is happeneing.
As you may have read in the "Suffering sucatash" thread, things are not pretty at the ILL house these days. Ambassalander is on hold till further notice. Once things get straightned out at home, then we (wife and I ) will look at reviving the project. I can not do much more till there is a couple of thousand laying around looking for a use. I have a little that can be done but mostly just cleaning and the such.
Hang in there everyone and keep going.
This is not a plea for Karma....
Tedd Ill
AIR#3788 TAC IL-10
Old 09-26-2005, 07:31 PM   #46
till's Avatar
Lisle , Illinois
Images: 108
Update time.
Things are starting to turn tward the up side finally. Most of the big projects are done or nearing completion. I have cleaned out the Overlander (parts trailer) and will be using it a couple of times in October to just get out before I get out of my mind.
I may have even found a source of funding for the "next big step" on the Ambassador!!! Yea!!!! Ambassalander here we come!!!!
See some of you out in Pacitonica (or somehting like that)
Tedd Ill
AIR#3788 TAC IL-10
Old 01-27-2006, 07:45 PM   #47
till's Avatar
Lisle , Illinois
Images: 108
WOW four months....
Well I have checked and the funds are in the bank for axles and floor. I will start to remove one axle to take to Axis to have a copy made. I plan on have the same weight rating as the originals which is 2300 lbs each vs the newer 2500 lbs. I do not want too stiff of a ride on the trailer. Rivet gun is on order and I remember there being comunity calicos floating around?? Will have to look into that....
Tedd Ill
AIR#3788 TAC IL-10
Old 01-27-2006, 10:38 PM   #48
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
tedd
when you get franken trailer riveted together you can use my cyclo to polish it!
john
Old 01-28-2006, 07:50 AM   #49
till's Avatar
Lisle , Illinois
Images: 108
I just realized that I typoed big time.....
It should be 3200 lbs axle vs. 3500. sorry.
The polish vs clean and reclear coat is something that is getting a lot of discution around here..... not "clear" winner yet.
Tedd Ill
AIR#3788 TAC IL-10
Old 06-27-2006, 06:28 PM   #50
till's Avatar
Lisle , Illinois
Images: 108
This is the end.
R.I.P for the Ambassador. The dismantlement has begun and will be over by the 4th of July. Just too much work and I guess another neighbor that does not like a pair of Airstreams around. Parts are going to fix up the Overlander that I have. Depending on the out come of the other Overlander I was told about I may just scrap out the Ambassador or cut it up to salvage the Overlander with a splice amidships.
Tedd Ill
AIR#3788 TAC IL-10
Old 06-27-2006, 10:35 PM   #51
ALUMINUM OBSSESSION
1993 34' Limited
Hamilton , Ontario
Keep up the good work!!!!!!!!!!!!! I replaced the whole front end on my 1993 airstream classic limited 34' . Some people thought I was crazy taking on this project. But now that it is 85% done ,they can't believe it is the same trailer. Don't get discouraged just keep working on it !!!
william Haym is offline   Reply With Quote
Old 07-01-2006, 09:13 AM   #52
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Ambassador parts
Tedd, I am still in need of the small screen for the window to the right of the entry door for my 67'. If you don't have that one any other curved screen of the same height would do as the frame on mine is what is broken. I could take one apart and repair mine with the curved aluminum frame. I think the height on all of the screens is the same but it must be a curved frame. If you have one please PM me and let me know what want for it and shipping. Thanks, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-01-2006, 06:09 PM   #53
till's Avatar
Lisle , Illinois
Images: 108
Well the shell is in three pieces. I will be removing the rear section tomorrow.
Ed. I think that shipping will be no big deal. PM your address and I will see what I can do.
I want to trade a 29" Curved Corning window for a 17" one. Let me know.
Tedd Ill
AIR#3788 TAC IL-10
Old 07-01-2006, 10:47 PM   #54
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
R.i.p.
Tedd, At least the Ambassador is going for a good cause... (to help out with the re-building of the other coach)! I think the name "Frankenlander" would be most appropriate for this newly resurrected Airstream. ALIVE!... IT's Alive! and the Ambassador gave its' last full measure to insure the Overlanders' survival. What more could any Airstream do than to give it's life..... for the life of it's brother. I think Wally would be proud. I'm sure the neighbors will be happier too! Check your PM's for my address and thanks again. Ed
Old 07-03-2006, 07:57 PM   #55
till's Avatar
Lisle , Illinois
Images: 108
Warning, graphic images too follow....
This is not for the faint of heart or weak of stomach.
I now have a 6 foot Ambassador. Well the whole thing is now 20 feet, but there is 6 feet of aluminum for a Bambi-esk like coach up front.
ID:	23132   Click image for larger version
ID:	23134   Click image for larger version
Tedd Ill
AIR#3788 TAC IL-10
Old 07-03-2006, 10:33 PM   #56
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Leftovers Anyone?
Say Tedd, Are the wheel wells on the leftover frame section galvanized? Mine look like fiberglass...(that is what's left of them!) If they are could you get me some close-up pictures of how they are made and attached? Thanks Ed
1967, 1967 ambassador
