Old 10-27-2017, 03:01 PM   #1
Jeffersonville , Kentucky
69 Ambassador Frame On
My first post.
Iíve been lurking here for a while, and study study study.
I have finally jumped in to our 29 foot 69 Ambassador project.
My wife bought this before we met. If has sat outside at our place for 3yrs and a few at her place before that.
The floor is rotted at the front and back. And we decide to redo it.
ID:	297812   Click image for larger version
Dremel is offline   Reply With Quote
Old 10-27-2017, 03:03 PM   #2
Plattsmouth , Nebraska
Best of luck to you.
Jhiner1978 is offline   Reply With Quote
Old 10-27-2017, 03:03 PM   #3
Planning on a shell on floor replacement. Hopefully it will stay on that plan.
It is now gutted.
Only the water heater is still there. Looks like I have to take off some of the belt line in order to get it out.
ID:	297814   Click image for larger version
ID:	297816   Click image for larger version
Old 10-27-2017, 03:04 PM   #4
A New Home.
Move it into the barn so that I do not have to worry about the rain
Old 10-27-2017, 03:05 PM   #5
Removed my first panel
Old 10-27-2017, 03:06 PM   #6
All panels are out except the end caps.
Insulation was not a major mouse trap.
Things discovered.
Floor rot.
PO put down 1/8Ē plywood on the entire floor during some previous rebuild ( but did not fix the real floor )
Leaks at front and back windows. Water in the header.
A number of Olympic rivets in a few places used to fix something
A internal Rib was bent and out of place. Rivet holes filled with silicone.
Pics to come.
Next up is removing end caps, wires, water heater
ID:	297820   Click image for larger version
Old 10-27-2017, 05:47 PM   #7
1966 22' Safari
Fredericksburg , Texas
Looks like a fun project. Having inside storage while working makes all the difference in the world. Donít throw anything away in the event itís unobtainable and take a lot of pictures. Good luck and enjoy. Bubba
Bubba L is online now   Reply With Quote
Old 10-27-2017, 06:49 PM   #8
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I'll second the inside storage.
Good luck!
Dingo Girl is offline   Reply With Quote
Old 10-28-2017, 08:33 AM   #9
Thanks, I'll be taking plenty of pictures as I go.
Yes, the inside storage will help a lot. Especially keeping the rain off when things like Windows are being worked on.
Old 10-30-2017, 01:21 PM   #10
Everthing is out. Including the end caps and the wiring.
I've done plenty of electrical, plumbing, basic house building, so I still feel comfortable. No expert, but comfortable. I've also completely rebuild a classic car, so all those experiancees, will help.
ID:	297986   Click image for larger version
Old 10-30-2017, 01:22 PM   #11
Street side acoss from door, This rib is all out of wack. Guess the skin was pulled into shape, but left the rib.
Old 10-30-2017, 01:27 PM   #12
And the back where the Bath was, Full of Olympic Rivets.
Top three panels and the lower right ( from the inside ) must have all been replaced.
Will have to decide if to leave alone, or switch out to buck rivets.
I will be taking out all the windows and rebuilding them, so will have to choose olympic or buck for that also.
ID:	297991   Click image for larger version
Old 10-30-2017, 01:27 PM   #13
OK, next to search on how to rotate my portait pics.
Old 10-31-2017, 06:08 PM   #14
Moving right along
Old 10-31-2017, 07:03 PM   #15
1966 22' Safari
Dremel, from what I understand from listening to the VAP and threads I have read, Olympic rivets are not structural. I know that a lot of people replace windows and minor patches with Olympics, but not end caps and structural panels. I think once you get into the drilling out of existing rivets and bucking in new, you may decide to remove the Olympics. Whatever you think. Youíre well on your way. A lot of fun. Good luck, Bubba.
Old 11-01-2017, 01:30 PM   #16
Thanks for the advise.
I plan to get the solid rivet tools. With a bit a practice, I'll decide if I want to replace the Olympics. Now is the right time to do so.
Old 11-10-2017, 12:03 PM   #17
a little progress
Since the last post, I have been figuring out how to get out the old sub floor.
I first pulled up the 1/8 board that was nailed to the subfloor. Used a crowbar and muscle.
Then cut the heads off the bolts.
I found that an osculating tool with a metal cutting blade works great to get under the C Channel and the other bolts.
However, I went through 2 blades and they are expensive.
Also used a cut off wheel in my angle grinder.
used a circular saw and sawsall to cut out sections.
I have the first 8 foot or so out. Looks like a Squirrel or Mice were living here and had their nut storage.
Pulled out the insulation and vacuumed.
The Steel frame looks to be in good shape.
I will wire brush it and then prep and paint with POR15
I do not know if this is how all 69 airstreams are, but my belly pan is one big flat piece. It rivets to the pieces that curve up to the side skin.
So , I can drop the bottom part so that I will be able to get to the bottom of bolts, and later insulate.
I am going to try to do this Floor replacement in sections.
Drop the belly pan in the front and rear of the axles.
Make floor pattern off what is left of the original floor onto 5mm luan type board. Then test fit it.
I will then use that as a pattern for the 5/8 or 3/4
POR15 it
Then put in the front 8 ft
Repeat on the rear section
Then Middle section.
Along the way, deciding on tanks and other stuff that goes in the floor.
I am trying to keep moving along, usually get about 2 or 3 evenings and 1 weekend day to work on it.
Received my buck rivet kit from VTS.
Will find some time to practice on some scrap.
They were out of the Olympics, but will get some of those to use in proper areas when they get more.
ID:	298754   Click image for larger version
ID:	298756   Click image for larger version
Old 11-10-2017, 12:48 PM   #18
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
While you're at it...
Something you may want to consider while you have the front subfloor out is to weld a couple of cross braces across where the tongue enters the body of the frame. Seemed like quite a span without any support.
I did so on mine and it made a huge difference in terms of support there.
Below is a progress picture of what I'm talking about...
I welded the angle iron to the long span for additional support.
1" square tube fit just right and happened to be what I had laying around
Ian
Iansk is offline   Reply With Quote
Old 11-10-2017, 03:03 PM   #19
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I used bolt cutters to get the bolts in the C-channel out. Horned well since my floor was such a rotted mess
Old 11-17-2017, 01:54 PM   #20
belly down in front
Thanks for the idea's. That is a big space in the front.
Last Monday I got under the AS, and drilled out the rivets for the flat part of the belly. Went all the way back to the wheels.
This way I will be able to put the nuts of the bolts for the floor.
Layed some thin plywood on the ground to protect the skin from rocks, etc if I need to lay on it when painting or putting the nuts on.
Anyways, while doing this, I got cra* dumped on me that was still in the belly sides. Not much, but enough that the next few days, were spent fighting off what feels like a head cold. Probably breathed in a bunch of it.
Should have had on my respirator.
Just now getting over it. So, if that was the cause, then I wasted 4 days recouping.
ID:	299333   Click image for larger version
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 11:46 PM
Frame Rot - New Frame jcawley1 Repairing/Replacing Floor &/or Frame 3 09-01-2014 09:30 AM
Advice on gaucho/jacknife frame frame & wall remodel chiefbrody General Interior Topics 0 01-30-2013 05:38 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 10:55 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 06:55 PM
