Old 02-09-2019, 02:32 PM   #43
Jeffersonville , Kentucky
Lots have been done.
Maybe I can find the pics and finally update this thread
Floors are bolted in
belly pan is insulated with rock wool
New 4x8 sheets used for belly pan
New axles are installed
front wing and center windows removed and reinstalled. Buck rivited.
one wing plex glass removed and polycarbonated reinstalled
All olympic rivits removed and newly bucked
All inside rivets and seams covered with trempro
AC removed and new seal put on. ( will use this ac untill it dies ) but framed it up so that a new one can drop on.
New tail light covers and led bulbs
New scare light
Adapted the 2 ceiling fans to Maxxfans
New tv antenna put on
Replaced the antenna mount
New LED marker lights all around
painted tongue
layer of the foil bubble stuff on walls ( will fill remainder with rock wool)
All AC 110v lines have been ran to their locations
All DC lines ran
( sill have to run a few things more that will be in the walls )
I think we have decided to make our own end caps.
Deciding on aluminum or wood
Going to do our own rear bath layout
Dremel is offline   Reply With Quote
Old 02-09-2019, 07:46 PM   #44
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You are really going after it. Your 69 Ambassador will be very well built and very nice when done. I stumbled onto your project thread and have enjoy reading it over.
Renovating a vintage Airstream is a big, big project.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 02-10-2019, 03:34 AM   #45
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Great progress!
Dingo Girl is offline   Reply With Quote
Old 02-10-2019, 06:18 PM   #46
Some pics of the progress. Somewhat in order.
( these are before the floor )
Repaired the wheel wells. There were some tears in the metal. I riveted on patches where needed. Painted inside with black rubber stuff.
Reinstalled
Old 02-10-2019, 06:20 PM   #47
floor going in
3/4" high grade plywood that has been polyed with multable coats.
I used elevator bolts in the middle. and 1/4" bolts in the channel and outriggers
ID:	333345   Click image for larger version
Old 02-10-2019, 06:26 PM   #48
I got my GREY tanks from vintage trailer supply.
4 in deep. I have been told that 5 " would have worked.
anyways, since I used 4" , I could make my holders by putting then on top of the bottom part of the cross members.
I used 2 pieces of 1/8" steel bar and 1 piece of angle for each tank.
The tanks have a plug in the bottom to drain, one in the top for breathing and filling, and then they connect and pipe out the back towards the blank tank.
In the pic of the floor, you can see the cutout for the fill
One tank is over the front axle , then an empty bay, and then the second tank
ID:	333347   Click image for larger version
ID:	333349   Click image for larger version
ID:	333351   Click image for larger version
Old 02-10-2019, 06:29 PM   #49
With the tanks, There would have been room on the far side to run 4 or 5" round solid duct work to connect the front square duct to the rear duct.
However the decision to go with catalytic has been made. So I skipped this.
Old 02-10-2019, 06:32 PM   #50
The front window and wing window at some point were olympic riveted.
So was at least 3 rear panels , rear window, and a bow or two.
Cut out all the olympics, and bucked
ID:	333354   Click image for larger version
ID:	333356   Click image for larger version
Old 02-10-2019, 06:35 PM   #51
replaced the polycarbonite in one of the wings, I could take the screws out and replace. The other wing was welded together, so I will live with the poly in it.
To bad the glass was broken a long time ago.
Clamped the poly down to cut.
ID:	333359   Click image for larger version
Old 02-10-2019, 06:39 PM   #52
Putting in Maxxfans.
Cut the rounded opening square.
Decide to pop rivet on a few pieces of aluminum angle
Then drilled and Tapped for the Maxxfan mounting trim
This way I can use machine bolts instead of sheet metal screws
The pop rivets will be under the trim and not seen
ID:	333362   Click image for larger version
Old 02-10-2019, 06:43 PM   #53
Cleaning up and resealing the bath fan. In order to take off, you had to remove the hat. Of course, the screws broke off. Had to drill and tap new holes.
Bath fan works fine.
Kitchen fan will need work or replacement. Makes a lot of noise
Old 02-10-2019, 06:46 PM   #54
Decided to keep the old coleman mach ac for now.
Took it off and put on a new seal.
Framed up the opening.
None was there. This will give a solid area to clamp the ac to.
Also designed it for the standard 14x14 for a new ac in the future. Just cut out the center piece of wood, and good to go.
Old 02-10-2019, 06:53 PM   #55
Sealed all the seams , rivets, and both sides of the ribs with Trempro.
Note: I did some with trempro. Then being out of tubes, I thought I would look local. Found some masterseal NP1. The tech sheet sounded close to trempro.
used 14 tubes of it. went on fine, looked fine, would have worked fine.
However, the fumes it gave off are too strong, still smelled a week later.
Ended up peeling off all of it. and redoing with trempro.
lots of time and energy wasted because I did not want to wait for a shipment of trempro.
Luckily all the smell went away after the peeling. even though I know there is remnants still there.
ID:	333367   Click image for larger version
Old 02-10-2019, 06:57 PM   #56
Insulated and boxed in the wheel wells
New BAL stabilizers. The old ones had bent brackets and some breaks. Considered fixing, but this is easier. Was ging to make them electric, but a drill works just as good
Found this on the wall of our 69. dated 9/27/68 nice to know when production was.
ID:	333369   Click image for larger version
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 10:46 PM
Frame Rot - New Frame jcawley1 Repairing/Replacing Floor &/or Frame 3 09-01-2014 08:30 AM
Advice on gaucho/jacknife frame frame & wall remodel chiefbrody General Interior Topics 0 01-30-2013 04:38 AM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
