Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Ambassador > 1966 - 1969 Ambassador
Old 09-21-2011, 04:06 PM   #1
1969 31' Sovereign
1951 21' Flying Cloud
Alex , Oklahoma
1969 ambassador Goucho
Need help, front Goucho has only two cushions. The large one you set on and the back one with curved edges. What is the size of the third missing cushion? The Goucho frame is really in bad shape. Can someone share measurement of the framing? When I pull mine out it tilts forward is it suppose to be attached somewhere on the back? The floor was all rotted. I have the trailer gutted at this time so I can’t take any photos. But, when I put it back together I would like to do it correctly. Maybe there is someone who has been there and done that.
1969 Sovereign
1951 Flying Cloud SS#7062
AIR #18751
CJ of Okla is offline   Reply With Quote
Old 09-21-2011, 05:50 PM   #2
SteveH's Avatar
Common Sense , Texas
I don't have the size, but you should be able to figure it out fairly easily. There were three cushions, the big one you sit on, the one in the back that fits the curvature of the trailer inside body, and the third one goes between those two, and is sized such that the entire space between the front of the gaucho frame and the wall is all coushion.
The middle coushion is attached to the bottom large coushion so it is hinged, and folds up when the gaucho is pushed in, forming the backrest of the gaucho.
Regards,
Steve
Old 09-21-2011, 06:20 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have a 69 ambassador but we are away from home right now.(in a different trailer) I can probably come up with the info you need when i get home in a few days.
My recollection is the curved cushion is against the wall behind the seat cushion. The back cushion is connected to the seat cushion by the upholstery.
Is the back cushion what you need info on.
Will check it out next week.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
RickDavis is offline   Reply With Quote
Old 09-21-2011, 06:30 PM   #4
1969 31' Sovereign
Alex , Oklahoma
back cushion
I believe the back cushion is what we need. As the goucho isn't in good shape it is hard to tell what size the back cushion is. Have a save trip.
1969 Sovereign
AIR #18751
Old 09-22-2011, 05:36 PM   #5
1969 31' Sovereign
Alex , Oklahoma
Rick, My bad I need the information on the cushion that has the curved edge. When you get home if you will private email me. I would like you to take some photos so we can see how the goucho frame is suppose to look. Thanks
1969 Sovereign
AIR #18751
1969 ambassador
1969 blackwater tank tracker Waste Systems, Tanks & Totes 1 09-11-2011 11:57 PM
1969 Airstream Overland Land Yacht triterra Airstream Registry Discussions 0 08-19-2011 08:32 AM
Kalaka :: 1969 AS Tradewind monah Airstream Registry Discussions 0 08-19-2011 08:32 AM
She :: 1969 Airstream Sovereign calivw78 Airstream Registry Discussions 0 08-19-2011 08:32 AM
1969 Sovereign :: 1969 Airstream Sovereign evers310 Airstream Registry Discussions 0 08-19-2011 08:31 AM
