Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Ambassador > 1975 Ambassador
Old 04-28-2005, 05:58 PM   #1
campergirl
Profile:  Mechanicsburg , Pennsylvania
Weights
Hi again.
does anyone have the gvwr and dry weight for the '76 Land Yacht Ambassador. 29' ?
Doesn't have to be exact but close enough for transferring a title without the weights noted.
thanks in Advance
Peggy
campergirl is offline   Reply With Quote
Old 04-28-2005, 07:34 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Have you seen this on Airstream.com? I believe it will answer your questions regarding the weights ~
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
InsideOut is online now   Reply With Quote
Old 05-01-2005, 06:36 AM   #3
campergirl
Thanks Shari.
that gave me the dry weight. the gvwr should be on the camper right? Problem is the camper is 130 miles from my house. Ohio title does not state the weight for some reason.
Old 05-01-2005, 08:36 AM   #4
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Weights
Greetings Peg!
Originally Posted by Peg
Thanks Shari.
The GVWR can be a bit difficult to find for some of the Vintage coaches -- my '64 Overlander International didn't have a placquard on the coach, nor did the owners' manual list the information. When I contacted Airstream, (this was in 1995) they weren't able to give me the GVWR. I ended up estimating the GVWR by adding 1,600 pounds to the empty weight when registering the vehicle.
I suspect that by the time your coach was produced that the information was probably required to be posted on a placquard attached to the coach, and may very well have been found in the owners' manual as well (I know that by '78 the information was posted on a placquard on the front of my Minuet and was also contained in the owners' manual). If someone with a similar coach doesn't answer your question by Monday morning, you may want to contact Airstream Technical Support for a dfinitive answer. You can find the contact information for Airstream Technical Support at:
http://www.airstream.com/company/contact.html
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 05-01-2005, 09:01 AM   #5
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Peg,
According to my 1975 Owner's manual the GVWR for all 29' and 31' Airstreams regardless of configuration is 7100# . Depending on configuration the dry weights range from 4765#-4855# plus options Tongue Weights range from 485#-650#. If you will post a more detailed description of your unit; twin, double, center bath, rear bath and a list of options...AC, jacks, vista views etc. I can give you a better set of numbers. These are based on the 1975 manual but there were not too many changes between 1975-76 model years.
Aaron
WBCCI #2449 AIR #2495
Old 05-01-2005, 06:11 PM   #6
campergirl
Weight of '76 LY
Hello and thanks.
This unit has the rear double bed, electric hitch, roof ac. I'm sure the plate has the weight but the trailer is over 200 miles from my house, therefore Im in a dmv dilema. Thanks for your help.
Old 05-01-2005, 07:36 PM   #7
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Unhappy
Hello and thanks.
Hi Peggy,
Now I am over 200 miles from my manual But I will get you the actual number when I get home this weekend. But for the DMV IIRC they want the gross weight and that is 7100#. If you need a net weight just shoot down the middle.
Aaron
Old 05-03-2005, 03:38 AM   #8
campergirl
Weights Found
Aaron,
That's ok, I got the title work completed yesterday. I used 7100 gvwr. I think that should be ok.
Thanks for helping out.
Peggy
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
manuals available maznblu 1977 Sovereign 10 04-16-2003 09:56 AM
RV weights and balance gwsullivan Link Archive 0 08-21-2002 02:50 PM
Trailer weights, hitch heights & more... ameeker Airstream Trailer Forums 1 06-25-2002 04:42 PM
Trailer weights davidz71 Our Community 6 05-28-2002 10:55 AM
