Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Ambassador > 1975 Ambassador
Old 05-23-2008, 12:23 AM   #1
Mexray
Mexray's Avatar
Profile:  1978 29' Ambassador
Stockton , California
LED Tail/Stop lights for 70's AS...
I couldn't find any direct LED replacement units for the old Marathon units in our 78 Ambassador...so I started to nose around one of my local Trucker's supplier of Chrome and LED accessories.
I found that the LED units in the front fender type turn signals were real close in size. I was going to have the store owner order only the RED LED units, but had a pile of used/come backs that he let me rummage through to get four good RED LED units...all for $20...a real score!!!
I had to grind all four edges to make them 'square'...they had a slight curve. I also had to grind a 'notch' on the back so that they would recess into the AS's tail light casting where I removed the Marathon type lens and 'bucket' that held the old bulb.
I also had to slightly notch the mounting holes 'inward' toward the center, about 1/8 inch to match the screw holes...I used a small bit from my router to do the job neatly.
I can't believe how much BRIGHTER these LED units are compared to the old light bulbs! You couldn't see much light from the old units during the day...and now they stand out for all to see! At night they are 'blinding' and can't be missed...I hope!
Click on image for larger view:
Here's the entire rear view...there are two tail/stop LED units on each side; on both sides of the Back UP lens (unchanged). The side corner 'marker' type light have been upgraded to an LED unit also. Red/White reflective tape has been placed on the bumper. The three upper Marker lights are also being upgraded to LED units next week.
Here's a close up view of the LH assembly.
Here's the kind of Large Truck type forward/fender LED Turn signal units that I removed the RED LED units from:
Old 05-23-2008, 05:31 AM   #2
Road Ruler
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Very Nice!
Old 05-23-2008, 06:31 AM   #3
crispyboy
crispyboy's Avatar
Profile:  1981 22' Excella II
alexandria , Kentucky
Were you still able to use the original gaskets or did you have to modify them too?
What were the specifications on the lights?
Looks very nice btw!!!
crispyboy is offline   Reply With Quote
Old 05-26-2008, 08:27 PM   #4
Mexray
Mexray's Avatar
the gaskets are in bad shape...I'm trying to find some replacements, or I'm going to have to cut some new ones myself...in all reality, if some rain gets into the tail light openings, I don't know how much actual damage it could cause...it would drip down the rear outside wall into the bumper area, and I don't think it would get near the floor.
I've thought about using some silicone sealer where the gaskets were placed, but it would be difficult to get the LED houshing out at a later date! Of course, one shouldn't have to remove them as they 'should' last for many years...
Don't know any 'specs' of the LED units...I just went to a trucker supply place and looked at the front type, double faced turn signal units that they had as show in my last picture. You could take one of your tail light lenses with you as a size sample...I don't know the MFG of these LED units I used, they are not marked, and I believe they are made in China...but there may be American types the same size...check the major truck light brands, Grote, Truck-lite, etc on the web.
Led Tail Lights For Classics Et Al vetdr Lights - Interior & Exterior 5 03-01-2007 08:04 AM
LED tail lights. outofcontrol Classic Motorhomes 51 07-21-2006 12:36 AM
4-Inch 10-LED stop turn tail light ($11) COUPON** Wabbiteer Electrical - Systems, Generators, Batteries & Solar 1 07-20-2006 09:27 AM
7 inch LED tail lights Inland RV Center, In The Vendor's Forum 0 06-22-2006 05:36 PM
Stop,Turn,Tail LED PROBLEM Wardinbb Lights - Interior & Exterior 5 09-17-2004 12:52 PM
