Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Ambassador > 1975 Ambassador
Old 05-27-2009, 05:15 PM   #1
Profile:  1975 29' Ambassador
North Huntingdon , Pennsylvania
Question Hatching out...
We just adopted a 75 Ambassador. One of the utility hatch hinges is cheesed up. I would like to try and keep her in her original state, but I can not find the top hinge to the refrigerator utility hatch. Does anyone know where I can find old parts like this, or any other parts from this era?
AmyK is offline   Reply With Quote
Old 07-04-2009, 09:37 AM   #2
Mexray's Avatar
Profile:  1978 29' Ambassador
Stockton , California
Airstream Registry
Check out Vintage Trailer Supply - give them a call, they have lots of stuff for older AS's...or
on the west coast, there's Inland RV who specialize in older AS's...
Let us not be too particular;
it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated (org...diamonds)
AIR # 11135
1978 - 28 ft Ambassador (Blue Halo)
2001 - Ford Excursion V-10 4x4
Old 07-04-2009, 10:22 AM   #3
Profile:  Corona , California
Amy,
Skip the replacement "J" hinge. You don't need it,
Get about a 6 inch long hinge.
Turn the door "upside down" and set it in place.
Attach the new hinge to the bottom of the door jam, and what is now the bottom of the door.
The lock will operate just as well at the top of the jamb as well as it did at the bottom.
An additional advantage, is now when you open that door, it will stay attached instead of you having to place it on the ground.
Never again, will you have a problem with that reefer access door.
It will work the same way as the rear compartment door.
Many owners, while their at it, change all the access doors, to open from the "top" instead of the bottom.
Also, should you forget to close that door and decide to drive off, you cannot run over it.
Andy Rogozinski
Inland RV Center
Corona, CA
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
