Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Ambassador > 1973 Ambassador
Old 05-08-2005, 10:54 PM   #1
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Found One!
Greetings Ben!
Congratulations on the find!
Originally Posted by Ironheadude
The only thing that might need some attention is the entry door. It sticks out a little at the top-front like it's a little warped or something. The previous owner rigged it with an extra seal around the top to stop drafts, but it's something I will want to fix or have fixed. Any ideas as to what would cause this? Will I have to take it back to Airstream? Will the whole door have to be replaced? A friend said the door might be sprung, but it closes fine. It's just pulled out...(not creased at all).
It sounds like you have a door that has been "sprung" by being blown open while in-transit or caught by high winds when parked. Both of my coaches had this problem when I first acquired them -- since I know that the door frames can be damaged if the repair isn't performed properly, I had Ace Fogdall RV (Cedar Falls, IA) repair each of the doors -- the repairs have been a success and I haven't had any further problems (eight years and counting on the Overlander, two years and counting on the Minuet).
Either way, I'm pleased as poopie to finally earn my place here as an official owner and can't wait to get out there. I hear the biggest rally of the year is coming up in Jax Ctr this coming weekend. Prolly too late to get a spot though. Wish me luck and anybody with similar door problems, any info would be appreciated. Thanks!
Ben
If you are thinking of the Airstream Homecoming Rally, it is a little more than two weeks away -- May 31 through June 5, 2005. See:
Airstream Homecoming Rally 2005 -- Details
You also aren't too very far from the site of the WBCCI International Rally where there is always a large Vintage section. The International runs from June 28 through July 4, 2005 in Springfield, MO. See:
WBCCI International Rally, Springfield, MO -- 2005
I will be attending these two Rallies as well as the WBCCI Region 4 Rally -- and if all goes as planned my '75 Cadillac Eldorado Convertible will be serving as the tow vehicle for the Minuet. The Region 4 WBCCI Rally in Fremont, OH (Sandusky County Fairground) from May 23 through May 29, 2005 is also on my travel itinierary. See:
WBCCI Region 4 Rally Information
While I cannot be absolutely certain, my intuition says that you shouldn't have any problem making reservations for any one of these Rallies.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 05-08-2005, 10:59 PM   #2
Profile:
Ben,
If you would like to attend the Detroit Forums Rally you can caravan with sfixx and loudruff. Of course you will have the only unpainted Argosy!
Anon is offline   Reply With Quote
Old 05-08-2005, 11:03 PM   #3
early's Avatar
Profile:
Lou do you have to join the wbcci or a local unit to go to a rally. I don't understand how that works. You have a rally in michigan, is it just memebers of your unit? I guess I need to read the old threads on the wbcci.
dawn
early is offline   Reply With Quote
Old 05-08-2005, 11:12 PM   #4
Profile:
dawn
Dawn,
What we have put together was a "Forums Rally". You don't have to be in the WBCCI in order to come to a forums rally. Heck, you can set up one of your own forums rally's down in Mississippi!
We have a Metro-Detroit WBCCI Unit that is putting on a "Buddy Rally" that will allow one of the WBCCI members to invite as many Airstream or Argosy owning firends to attend the rally. You can contact the WBCCI at www.wbcci.org and they will forward your contact information to the Units that are local to you.
The unique thing about the Metro-Detroit unit is that it is mostly working people. I do hear some people say that the WBCCI is for older folks. Well, it is if none of us join.
I would find out what forums members are near you and then start conversing with them. See what you can set up! If you need any help or advice let me know!
Old 05-08-2005, 11:14 PM   #5
Anna , Illinois
Images: 156
Found One!
Greetings Dawn!
dawn
The only time you usually need to be a member of the WBCCI to attend a Rally is one that is sponsored by a Unit or Region of the WBCCI or the WBCCI itself. There is an exception for "Buddy" rallies where non-WBCCI-members are welcomed as guests. Of the rallies that I mentioned in my earlier post, the only two that require WBCCI membership are the WBCCI Region 4 Rally, and the WBCCI International Rally. As a member of WBCCI, you can attend any of the rallies -- for instance, I am a member of Region 7 (Wisconsin Unit), but I will be attending the Region 4 Rally for the second time.
The Airstream Homecoming Rally is sponsored by Airstream/Thor, and is open to all owners of Airstream Products. In general, Forum rallies are informally organized, where each of the participants handles his/her own reservations with the selected campground.
Kevin
Kevin D. Allen
AIR #827
Old 05-08-2005, 11:22 PM   #6
early's Avatar
Profile:
Thanks Kevin and Lou. That helps alot. Didn't mean to hog your thread Ben. Look forward to hearing about your trip tomorrow. Dawn
Old 05-08-2005, 11:20 PM   #7
Profile:
How about if we give this thread back to the original post of buying his first Airstream!
Old 05-09-2005, 05:11 AM   #8
Rivetedude's Avatar
Profile:  Currently Looking...
Belle Chasse , Louisiana
Send a message via Yahoo to Rivetedude
Hey, no problem aobut the club posts! Actually I was kind of hoping to get some info on the clubs and which I should join etc. The homecomming is the rally I was talking about. Jackson Center is right down the road and it wouldn't be an expensive "spur of the moment" decision to go. I'll probably contact our factory rep for registration info unless any of you guys have the details.
About my stainless tambours, I never thought of the weight issue...maybe I'll use aluminum. Most of them are on one side and those slats are pretty thick. You get a couple thousand of the stainless ones on one side...yeah, that'd be pretty heavy...Thanks!
Ben
Rivetedude is offline   Reply With Quote
Old 05-10-2005, 06:20 AM   #9
Rivetedude's Avatar
Pics Pics Pics!
They're all uploaded. You should be able to link to them from my profile or use keyword "Ironheadude"
Ben
Old 05-11-2005, 04:07 PM   #10
Profile:
...You should be able to link to them from my profile or use keyword "Ironheadude"
Sorry dude - "404 error" forum problem keeps anyone from looking at the pix from your profile.
joatmon is offline   Reply With Quote
Old 05-11-2005, 04:00 PM   #11
Rivetedude's Avatar
Hey wait a minute! After getting the title, it's a '72 ambassador...not a '73. Oh well...still happy with it!
Old 05-11-2005, 04:26 PM   #12
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
check the serial number on the tag...front streetside corner. that will reveal the truth. check it against the serial number decoders on airstream.com
mine was wrong when I got it, too. or, I should say, the PO's registration and title were wrong. current title was corrected.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-11-2005, 05:06 PM   #13
Rivetedude's Avatar
I got the same error. I thought it was just my computer. I was able to attach the exterior pics in post #21 though...You might also be able to just go to the "photo gallery" link and look at pics uploaded yesterday under Ironheadude.
Old 05-11-2005, 05:11 PM   #14
Profile:
Nice trailer!
I will go look at the other pics now!
I really do believe that this is the first symptom of "aluminitis"!
Loss and found suekozin Insurance & Claims 10 01-21-2003 06:28 AM
Help with Interior Heights? sbernasconi9 Our Community 4 10-27-2002 09:33 PM
Found new A&E awning Dave-O Awnings 4 10-21-2002 09:15 PM
Logins.. 53flyingcloud Our Community 5 06-29-2002 02:10 AM
1985 310 found off road 1985air345 General Motorhome Topics 1 05-27-2002 01:15 PM
