Fresh water Drain
Hello fellow Overlanders,
I recently purchased a 1976 Overlander International in the fall. I am stumped on the fresh water drain. My particular layout has a bed/couch across the front and a bed/couch in the middle of the trailer, with a rear bathroom. My galley is the model with the one piece stove/oven combination. This makes access to the water pump area especially difficult.
My question is about the fresh water drain, I orginally thought the tank was curbside behind the galley, but after looking at other various blogs and from what I see on the trailer the tank is actually just ahead of the axles dead centre of the trailer and looks to be within the frame. I still cannot see any drain valves, the alum belly pan looks to be easy to remove with one large bolt in the middle any numerous smaller ones around the outside. Has anyone tackled this to put their own drain on?
Or, has any one tried using a drill pump or similar to syphon the water back out the fill access.
We camp off grid a lot and I would like to not only be able to dump the weight to travel, but also clean and flush the tank.
Thank you for your help.
