03-11-2018, 06:09 PM
#101
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Subfloor Perimeter Channel
We vintage Airstreamers often talk about the "C channel". It sits on the subfloor, bolted to the subfloor, and then the exterior and interior skins are bucked riveted to it. The distance between the skins is 1 1/2".
My 75 Overlander actually has two types of "floor channels" as Airstream calls them. The front and rear of the trailer have the traditional "C channel" that Airstream forms into a big loop matching the corners of the body. The straight sections of curb and street sides of my trailer have this extruded "C channel with a foot" that fits over the edge of the 3/4" subfloor. It looks pretty robust to me.
Here are photos of the C channel at the rear of the trailer, and the more robust floor channel along the sides of the trailer. (Note: The floor channel has been trimmed flush with the floor, and the interior lip bent over flush with the floor for the old 10 gallon water heater.) Reference also a photo out of the service manual showing there are indeed two part numbers for these two types of floor channels.
I don't know when these two types of floor channels were incorporated into the Airstream body design. Maybe in 1969 with the new body. I found this interesting in a strange vintage Airstream kind of way. Most folks wouldn't give a rip about it.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
03-15-2018, 05:27 PM
#102
1986 34' Limited
1975 27' Overlander
Conifer
Patch With Purpose
I made a patch where the old 10 gallon water was located. This project included "framing" around the patch area with aluminum including a "new" floor channel that is attached to the subfloor. The patch is Alclad.
I also made a patch for the interior wall covering the hole where the water heater was located.
I then drilled and installed new shore power and city water inlet fixtures. It is pretty standard stuff. I find it handier than digging out a shore power cord from the bumper storage and then attaching a water hose to the inlet located low on the frame rail at the very rear of the trailer.
The space where the old water heater was located has become a "utilities" area as that is where the AC power distribution panel is located, as well as a plumbing drain line and a vent line.
Next on the list is a new power panel with new breakers. Then I'll start the fresh water plumbing from the citer water inlet.
The patch will look better when I polish the whole trailer. The new water heater door will also be clad in Alclad.
David
03-16-2018, 11:05 AM
#103
1972 27' Overlander
Lafayette
, Louisiana
I just pulled my oven out as well, on the '72. It looks just like yours and in perfect condition---like it was never used. I don't want to throw it away, so if anyone on this site wants it and wants to pay to have it shipped, I'm happy to let it go. Also, had the idea to put the microwave in that space, but don't want it to protrude into the bedroom, so not sure how to cover that hole--maybe a piece of stained glass, or mirror.?
03-16-2018, 06:48 PM
#104
1986 34' Limited
1975 27' Overlander
Conifer
Hi Clarezy: Welcome to the vintage Airstream hobby. That oven located in the wall is a silly idea in my view. I believe Airstream wanted to increase storage space in the galley, and built in ovens were just beginning to become popular in new homes back then.
So I plan on using that space for the microwave. A microwave is a very handy gadget in an Airstream. We don't use an oven much while traveling. Many other folks wouldn't be without one. Anyway, they make "apartment size" microwaves that are not very deep or very heavy. I will pick one up someday, and then build a facia to make it look as nice as I can. I will still have the bump out over the twin bed. I'll get used to it.
There may be room under the cooktop in that extra storage space Airstream provided with the wall mounted oven. But my trailer doesn't have an outlet located there, and I don't like getting on my knees to set the microwave. Otherwise I have not thought of a good place for a microwave in the seventies Overlander.
David
03-17-2018, 06:31 PM
#105
1986 34' Limited
1975 27' Overlander
Conifer
New Electrical Distribution Panel 115vAC
I installed the new 115vAC distribution panel. Why? The old box had spaces for 4 beakers and all were used. I may run a dedicated circuit for the microwave. I haven't decided fully on this yet. And the old box was a bit rusty, and the breakers were as old as the trailer. Time for new hardware I figured.
With the new shore power connection outside of the trailer, the installation of the breaker box was straight forward. I did elect to mount the box a bit higher so you don't have to bend clear over to turn off the main breaker. You have to have your head in the game while wiring this up. A guy has to double check everything to insure it is wired correctly.
So I closed my eyes and plugged it in. No flash, no arcs, no buzz, no smoke. A good sign. Then I tested each of the three circuits; AC, back half of the trailer, and front half of the trailer. No problems found.
So I can cross another item in this Overlander renovation.
David
03-18-2018, 04:28 AM
#106
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
David
Nice patch job and utility installation. Moving the water heater is a very nice improvement. Wally would approve!
Dan
03-18-2018, 06:15 PM
#107
1986 34' Limited
1975 27' Overlander
Conifer
Thanks Dan: As you know I did the same thing in the Trade Wind. A 6 gallon water heater is close to 50 pounds when filled. The battery was close to 65 pounds. I also moved the gray tank forward one frame bay. I speculate Airstream added weight to the rear to reduce tongue weight so you could pull an Overlander with a Ford Fairlane 6 cyl and still have the front wheels on the ground. Or at least try to pull it.
The patch will look better once I polish the rest of the trailer. Next winter's project.
David
03-19-2018, 04:52 PM
#108
1986 34' Limited
1975 27' Overlander
Conifer
Holding Tank Drain Manifold Complete
I made the final pipe attachments to the Valterra valves and then to the 3" sewer pipe out the side of the frame rail. The valves are located in the bumper storage compartment instead of the rear cargo department. I did this as I was reluctant to cut holes in the rear subfloor and I see no advantage in having the valves actuated in the cargo compartment. I am easily able to lift the bumper storage lid and actuate the valves.
The bumper storage compartment is a "basement" area. It will be wet and dirty sure. There will be a barrier wall between the tank compartment and the bumper storage area. The tank compartments will be heated as usual.
I won't insulate the area until I finish fresh water plumbing and fill the tanks with water and then test for leaks.
I also included a photo of the trailer's utilities connected in their new locations. Not fancy, but it should work good.
David
03-24-2018, 10:22 AM
#109
1968 24' Tradewind
1968 26' Overlander
Detroit
, Michigan
Your tank plumbing looks practical and well thought out. Very simple and accessible design.
03-24-2018, 05:36 PM
#110
1986 34' Limited
1975 27' Overlander
Conifer
Thanks Atomic 13: It isn't nuclear powered like I would assume someone with a user name of Atomic would consider.
David
03-24-2018, 05:59 PM
#111
1986 34' Limited
1975 27' Overlander
Conifer
Fresh Water Plumbing Begins
I laid out my plans and made a list of the materials I need. After the trip to the hardware store ($200) I started in. Brass PEX connections are expensive.
I've completed the fresh water inlet, the hot water heater bypass valves, the toilet connection, and the bath sink shut off valves.
Next is the shower valve connections and then the long run to the galley sink and pump. With a bit of luck, I should be ready to pressurize the system late next week, less faucets. I'll test it with 40 psi air first, then real water.
I want to purchase new faucets for galley, shower and bath sink. The originals are pitted and seem partially blocked inside. I don't need anything fancy. I won't install them until I'm in the final assembly phase.
There is a screw on cap on the Shur Flow water inlet assembly that I screwed to the side of my trailer. There is a pressure regulator (65 psi) built into this plastic assembly. I ASSUME I can screw on the cap instead of installing a check valve. I'm likely to leave the cap on except when we are connected to city water somewhere just to keep the system somewhat clean.
David
03-27-2018, 08:25 PM
#112
1986 34' Limited
1975 27' Overlander
Conifer
Fresh Water Plumbing Ends
I now have the fresh water plumbing system completed from city water inlet to fresh water tank. The PEX system is easy to work with and I think has less pressure drop than all the copper I took out of the trailer.
All I have is the main lines completed. I will air leak test tomorrow (fingers crossed). I have to install my new faucets before I try the new pump and put water in the system. I installed a standard shut off valve for each faucet line.
Installing the faucets will be with steel braided flex lines. Installing new faucets means I have to put the bathroom back together. I also have to wire up the new pump. They want an exclusive 15 amp circuit with switch. I'll have to figure all that out too.
A lot done and a lot more to do...
David
03-27-2018, 08:53 PM
#113
NO HUMBLE OPINION
1968 20' Globetrotter
ANN ARBOR
, THE GREAT LAKES
Good to see that you're not hammering your Airstream into an aluminum pyramid since the UFO sighting...
Thanks for your informative thread
03-28-2018, 06:35 PM
#114
1986 34' Limited
1975 27' Overlander
Conifer
Thanks aluminuminum: It's enjoyable to work on these vintage Airstreams. Documenting how a guy goes about certain aspects of the project may help someone else doing similar work on a similar model.
I did see a "fireball" UFO, honest. I looked it up on a meteor sightings website and at least 4 other Coloradans were up at 4:40am MDT and reported seeing it. It was a spectacular UFO for me.
I enjoyed your comments about water usage. Colorado is in a significant drought since last summer. California is just emerging from a multi year drought. The people of Cape Town, South Africa are running out of water as their reservoir is dry. Water use there is limited to 5 gallons a day voluntarily.
I've implemented some new techniques to reduce my water usage a bit here at home. I won't waste water on watering the grass, dumb. Maybe next for me is a monthly shower schedule, 2 minutes max. A pit outhouse would help too.
David
03-29-2018, 06:28 PM
#115
1986 34' Limited
1975 27' Overlander
Conifer
Fresh Water Plumbing Test Success
Today I pressurized the fresh water plumbing circuit with 35 psi air. Much to my surprise and satisfaction there were no leaks heard (hisssss) or detected with soap solution. The system held 35 psi air all afternoon. It still has air pressure in it and I shall see what the gauge reads in the morning. The PEX system is a wonderful thing. Bye, bye old copper plumbing.
I also turned on the new pump and it really sucks! It drew water out of the fresh tank in about 2 seconds. That was a good sign too.
Now I start the next phase of this project. Reassembly!
I need to refurbish the bath cabinets and install the faucets. The bath plastics have been painted at least once. I plan on painting them again, especially the tub.
David
04-03-2018, 06:01 PM
#116
1986 34' Limited
1975 27' Overlander
Conifer
Bath Plastics Painting Planning
I have six major plastic parts that I intend to paint as an overall improvement to the bath appearance. I've done some research posted by fellow vintage Airstream enthusiasts. It seems to me the 2 part epoxy paints are the best bet, although spendy. It also seems best to spray paint these parts in lieu of brushing or spray can.
I read some commercial restorers use an automotive paint designed for plastic bumpers and the like with good results. This selection gives more color options for sure.
Spray can paints like Krylon Fusion is a possibility on the "vertical" plastic parts that don't get wet, stepped on, or scrubbed hard. The large piece under the sink countertop is such a piece where Krylon may work.
I have half a mind to take the parts to an experienced spray painter with my paint selections. Producing a decent appearing spray painted surface takes skill and practice. I am not a spray painter unless a guy like runs, drips, orange peel, and thin spots.
Here is a photo of the six parts I need to prep and paint. They have not been prepped for painting yet at all.
David
04-04-2018, 06:04 AM
#117
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland
Everything is looking fantastic! Tough decision on the painting. You could sharpen your painting skills by practicing on a similar item. But like you say one little run or thin spot? If not comfortable it maybe best to leave it to a professional.
Thanks for more inspiration!
04-04-2018, 06:43 PM
#118
1975 27' Overlander
Toronto
, Ontario
David, the space you have in your garage to neatly sort and organize everything makes me jealous! It has been tough to hunt for your thread but glad I found it. You are an excellent reporter! I am about to wrap my head around the electrical and plumbing so this helps. I have removed some plastic window trim from the front wing windows and have the same dilemma as yourself. Not sure how to go about making it look good. Another consideration is that the paint you apply to the wall, if it's both white, might not be the same you use for your cabinets etc. I feel like I am going to give it a shot with an air pressurized spray gun and see what the result will be.
Best of luck and keep up the great work!
04-04-2018, 07:13 PM
#119
1986 34' Limited
1975 27' Overlander
Conifer
Thank blackbear: I'm glad my project thread is a bit helpful to you. That's the idea, Airstreamers helping each other.
I've got to figure out this plastic part painting thing. My bathroom was painted with a spray can I think. The tub has not been painted, but there was some kind of no slip mat in it, and it melted and got sticky gunk all over the bottom of the tub.
I checked out the POR15 2K website. A great product, hard as nails, but they don't mention it on flexible plastic parts. So I'm still unsure.
The answer is here in the Forums. I just gotta do my homework.
David
04-13-2018, 05:58 PM
#120
1986 34' Limited
1975 27' Overlander
Conifer
Painting Bath Plastic Parts
I have decided to have my bathroom plastic parts painted by a body shop. I'm going to use a paint formulated for plastic bumpers and the like. I took an old post by Colin Hyde where he states that is the paint and process he uses when restoring an old Airstream.
We have a small body shop here in our nice small town. It's a one man shop so to speak. His quote is reasonable. So that's the way I'm going. I'm painting them bathroom white, and then we will decorate with towels, rugs, shower curtain and the like.
There are many options for improving the plastic parts in these old trailers. My choice may not be the best. I don't always get a good finish when I paint with a spray can. My Iowa friend won't let me help paint his machine shed. My wife does all the interior painting in our house. I'm just not a painter/finisher.
My Overlander improvement project is on hold for about three weeks. We are taking the 86 Limited on a travel adventure to the southwest. Traveling is half the fun of a vintage Airstream.
David
