Old 09-24-2018, 02:45 PM   #1
1972 27' Overlander
Thornton , New Hampshire
Window gap what’s going on??
So our windows all have this gap so put new weatherstripping on hoping that was problem ...ya nope?? What do we try next ? This is then in locked tight position. We have tried the actual remake weather stripping and also just one we bought at store neither closes the space.
Gloria1972 is offline   Reply With Quote
Old 09-24-2018, 04:20 PM   #2
1994 34' Excella
Warren , Manitoba
Is the window in the pop hinge correctly, and if it is, has it been bent or pryed outward. A picture of the outside of the window would help. Did you get the proper weatherstrip from an Airstream supplier? there are 2 types, and I have used the "D" bulb type as I find that it seals better. Outof doors mart # is 38-0064. Have used it on many windows on various Airstreams that I have fixed and owned. Chris
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 09-24-2018, 08:49 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Yes, a picture of the hinge might help solve the mystery. The looks like a much larger gap than I would expect to see. Maybe some PO damaged or replaced all the hinges to cause this...
Old 09-25-2018, 11:52 AM   #4
1972 27' Overlander
Thinking it is pop hinge will grab more photos when I get chance/ we used the weatherstrip from Airstream supply and then tried another both windows still have this gap...if pop hinge was brutal to get back in so yes maybe that is it? How do we correct pop hinge issues? I will look at previous posts about this but any advice greatly appreciated
Old 09-25-2018, 11:55 AM   #5
1972 27' Overlander
Ok I am also now thinking hinge issues / any advice on how to fix pop hinge issues? I will research topic but any info you have and want share greatly appreciated/ it’s def more than a “weather seal” issue for sure
Old 09-25-2018, 12:27 PM   #6
1972 27' Overlander
Ok I just looked at great old thread I think they used to use buck rivets so when we w replacing the old pop hinge onto window we used pop rivets ..old thread I read said that fine but make sure to put pop rivets thru from back side which we did not I did from frontside looking at old buck rivets on other windows ...we did flatten the back of rivets before placing the weather strip but perhaps it’s just to much of a bump? Going take off the pop hinge / make sure it’s super straight re-revit the opposite way than I thought -try in window hope it looks better then weatherstrip again!!!! Starting over ....oh vintage AS love it’s not for impatient .
Old 09-25-2018, 01:39 PM   #7
1994 34' Excella
Warren , Manitoba
When I replaced the hinge on the windows I used pop rivets, but carefully hammered then flat and filed them down. I did rivet from the front, making sure that the hinge is on the correct way. Did you do all windows? If not, look at the windows that you didn't do and make sure that you are replacing hinge the same way.
WBCCI #7394
Old 09-25-2018, 04:27 PM   #8
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
See post 606 of my thread below on how I addressed the window hinge problem.
Old 09-26-2018, 07:55 AM   #9
Belegedhel's Avatar
Houston , Texas
If you can post a picture of the outside of your hinge, it may become instantly apparent what the problem is.
Old 09-27-2018, 09:19 AM   #10
1972 27' Overlander
thank you will do as soon as i find time to head out there....
Old 09-27-2018, 03:28 PM   #11
1972 27' Overlander
ID:	323843Click image for larger version
Old 09-27-2018, 04:29 PM   #12
Aerowood's Avatar
Arvada , Colorado
Yup, your problem is how the hinge is attached to the window frame. Can you buck rivet, or know someone who can?
Another picture of the window removed with a view of the area under the seal would be helpful too.
Old 09-27-2018, 04:48 PM   #13
1994 34' Excella
Warren , Manitoba
The back of the rivets are holding the window away from the frame. They must be filed or ground flatter. A "bucked" rivet is the preffered way, but pop style can be used if careful.
WBCCI #7394
Old 09-27-2018, 05:13 PM   #14
1972 27' Overlander
I personally don’t know how to buck rivet but will find someone who can, these two windows apparently are my trial error windows ..thank you for helping me
Side window with gap after weather strip. Sdmezurek General Repair Forum 0 08-09-2018 08:13 PM
Window seam gap - can it cause rainwater leak? RAH General Repair Forum 0 05-14-2016 04:01 PM
How to enlarge gap on window bar to accept new window vitzman Windows & Screens 9 09-20-2011 09:45 PM
window gap nbka1bm Windows & Screens 11 11-22-2007 07:20 AM
Gap between floor and shell tmcdougald Repairing/Replacing Floor &/or Frame 4 07-19-2005 05:44 PM
