Old 11-27-2014, 10:30 AM   #1
jwo9958's Avatar
Little Compton , Rhode Island
Running lights cord.
My new Overlander 1972 is missing the cord to plug in the running lights to the trailer hitch in truck. Where can I get one and what is it called. Thanks and Happy Thanksgiving !
jwo9958 is offline   Reply With Quote
Old 11-27-2014, 10:43 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It's called an umbilical cord. You can either make one yourself, or some Airstream dealers with an online presence offer them for sale.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 11-27-2014, 10:46 AM   #3
jwo9958's Avatar
Do you know if they all have the same 7 pin socket on the trailer. Is this a standard? Thanks.
Old 11-27-2014, 10:48 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Any RV shop will have it.
2004 Excursion 4x4
Old 11-27-2014, 10:52 AM   #5
terryV's Avatar
2002 31' Classic
Monroe , Iowa
I think they all have a 7 pin connector, but back in the good old days, the pins were round, and now they are flat.
Get the one that works with your TV, which should be flat, unless you have an antique TV, also.
terryV is offline   Reply With Quote
Old 11-27-2014, 11:02 AM   #6
That cable is called an "umbilical cable".
The original had 7 round pins on each end which were the plugs.
The sockets are on the trailer and the tow vehicle.
The round pinds are far superior to the flat blades, since they are "self cleaning" when you insert them.
Old 11-27-2014, 11:05 AM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Round pin connectors are still used on commercial trucks to this day, in my opinion they are as a rule superior to the RV style connector ends. (Yea, they are different from the old stock Airstream plugs)
I changed the socket in the trailer to the truck style socket, but til this day I have been too lazy to convert the plug on my TV.
Someday maybe..
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 11-27-2014, 11:13 AM   #8
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Get hold of the wiring diagram for your trailer's lights. My '73 was wired in a way that is not consistent with today's standard--had I bought an umbilical off the shelf, it would not have worked. I ended up reconfiguring the wiring on the plug on my trailer, replacing the plug with one that was more robust, and building my own umbilical (also called a "whip"), so that I could have round plug connections on the trailer end, and flat on the Tow vehicle end.
good luck!
Old 09-19-2018, 06:17 AM   #9
1972 27' Overlander
Brawley , 9
I am in the same situation but I have the original umbilical, I might have to cut the end off that goes to my tow vehicle and connect a modern 7 blade because I cannot find an adapter anywhere. Keep us posted on your end result!
Blakekm6pht is offline   Reply With Quote
Old 09-19-2018, 10:34 PM   #10
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Vintage trailer supply has all the parts of an umbilical if you need to replace something. Not clear on what your issue is exactly, but they sell both standard umbilical cables (also available at any RV suppy) and the end that connects to the 70s Airstream.
TheGreatleys is offline   Reply With Quote
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
