Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1972 Overlander
Old 09-07-2006, 09:18 PM   #1
310astream
Profile:  1983 31' International
Belle Fourche , South Dakota
Light Switches
My wife and I just bought a 1973 Overlander and are in the process of learning where everything is. As you enter the camper on the right (front) side there are two switches. The one nearest the door controls the outside light over the door. The one next to it controls nothing we can see and I assume it it for an inside light, but can't seem to find it. Any thoughts. Further forward there is an other switch that controls the outside spot light. Thanks. We learned a lot lurking and are anxious to get on the road a few times this fall before winter sets in.
Rick
310astream is offline   Reply With Quote
Old 09-08-2006, 01:33 AM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Rick,
Welcome to the forums!
On my 1975 that second switch is a three way that controls the light over the sink. I think on some other units it controls a different light. Hopefully someone with 1973 Overlander will let you know what theirs does...however there is no guarantee...
Aaron
WBCCI #2449 AIR #2495
Old 09-08-2006, 05:53 AM   #3
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
What Aaron said. Mine is still in pieces in the backyard, so I'll run check in a few minutes. The wall are still out, so I can trace the wire. But I recall that it goes to the lite above the sink. On some models, IIRC, it also operates a couple of other lights.
What is that line from "Miracle on 34th Street"? Something like "Maybe he's only a little crazy, like those men in Washington."
www.nesa.org
Air No. 6427
Jim & Susan is online now   Reply With Quote
Old 09-08-2006, 06:18 AM   #4
Jim & Susan
McDonough , Georgia
Images: 37
Well, I just went out and checked. It controls the lights over the Gaucho, the sink and possibly the center bedroom area. The wire disappears into a huge bundle in the center of the camper, so I can't trace all of it at the moment. Good luck with it.
www.nesa.org
Air No. 6427
Old 09-08-2006, 06:29 AM   #5
ticki2
Profile:  1976 25' Caravanner
Campton , New Hampshire
Check for a bad fuse . On my '76 the same fuse controls the outside light , the over the sink light and the ceiling light over the goucho . Some times the fuse is good but the connection is not . If you have a test light check to see if there is power to both sides of the fuse when the fuse is in. Good luck
ticki2 is offline   Reply With Quote
Old 09-08-2006, 06:33 AM   #6
310astream
Thanks for the replys. All the other lights in the camper are working-sink-gaucho-main. I'll do some more checking this weekend.
Rick
Old 09-08-2006, 07:55 AM   #7
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
On my '73, the switch powers the switch on the galley light. yes, I know that sounds odd. Its kind of like a mis-wired 3-way switch. It allows you to operate the light from 2 different places...kind of.
Power runs from the converter to the wall switch by the door; from there, a wire goes to the galley light. So if you leave this switch in the "on" position, you can turn the galley light on. If you have the galley light switch off, the wall switch appears to do nothing. If you have the wall switch off, the galley light appears to not work at all.
I just leave the galley switch "on" and turn it on and off at the wall. this way, I can get some light in a dark trailer from the door step, rather than having to fumble around in the dark looking for a switch...which I think was their intention.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-08-2006, 08:09 AM   #8
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
On my 75 TW the switches act as true 3 ways. It does not make any difference which switch you use (galley or door). Flipping either switch changes the on/off status of the light. I would think that this is the way it was designed to work.
Richard
Charter Member Four Corners Unit
Old 09-08-2006, 09:44 AM   #9
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
Ditto on my '74, until the galley switch went belly up - replaced it with a SPST and resulted with the situation described by Chuck.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 09-08-2006, 10:17 AM   #10
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Do I get to guess?
I vote for the scare light.
That's the light out side that has large clear lense on it usually between the door and the front of the trailer.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 09-08-2006, 10:46 AM   #11
azflycaster
Phoenix , Arizona
Images: 58
Originally Posted by Safari Tim
Do I get to guess?
On my 75 the scare light switch is on the other side of the window, away from the other two switches.
Richard
Old 09-08-2006, 12:10 PM   #12
eubank
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
Wellll, on our 67, I wondered for years about the magical mystery switch near the door. Looks like a regular household light switch, but didn't run a damned thing, even after exhaustive testing, testing, testing. Nor is it shown in any of the electical schematics that we have of the rig. A couple of years ago, I discovered that it does indeed do something: I was trying to trace down yet another electrical mystery when I turned on the furnace (to test 12V electrical) and subsequently flipped the magical mystery switch. It immediately grounded out the furnace circuit, causing the furnace to shut down.
So, well, I have no real idea what the original function might have been, but I do know what it'll do now.
Lynn
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 09-08-2006, 01:52 PM   #13
ticki2
This is how mine works on a '76
Old 09-10-2006, 07:25 AM   #14
310astream
Well the wife figured it out. It does control the galley light but it is not a 3-way switch.
Many thanks to the forum for help on this matter. What a wonderful tool!
Rick
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 09:43 AM
3-Way Roof Light Switches roadcam Electrical - Systems, Generators, Batteries & Solar 8 09-06-2004 02:31 PM
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 06:31 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
