Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1970 - 1973 Overlander
Old 08-01-2017, 01:22 PM   #1
Rockton , Illinois
'72 Overlander
Ok, I've looked at my 2nd AS and go figure, it's another 72. This time it's a Overlander not a Safari. The out side is darn near dent free. 1 straight panel could be replaced. Everything is original and works. The floor seems solid but can assume the rear floor is in need of replacement. If I got it, the under side skins would half to come off for inspection. The tires are 3 years old and brakes are new.
My question is, I think the guy is way high on the price. He's asking $12,000. Can anyone share there opinion on the price?
I have family that are pretty good at fixing stuff so keep that in mind.
Thank you in advance for sharing your opinion
jbknowso is offline   Reply With Quote
Old 08-01-2017, 02:59 PM   #2
1972 25' Tradewind
Calgary , Alberta
Sounds like maybe I bit high, but not too far off, if indeed everything works and is in 'good working' order.
My '72 things worked, but just barely, it needed a new fresh water tank, needed some belly pan repairs, actually needed lots of little repairs here and there... I ended up gutting it to start fresh, but that was always my plan. I paid the equivalent to 7200.00 US dollars. (In Canada and Airstreams are more scarce)
Monza is offline   Reply With Quote
Old 08-04-2017, 05:06 PM   #3
Thiss's Avatar
1971 27' Overlander
2023 28' Flying Cloud
Monmouth , Oregon
Seems steep. If I were to list my '72 Overlander it would be for about $15k, or less, and it has:
New axles
2 new tires 2 two year old tires
New aluminum wheels
New astrodome
New custom curtains
New fridge
All working systems
New LP tanks and regulator
Good battery
New waterpump
Still needs:
Rock guard
New AC
Permanent fix for Rear end separation.
Flooring
New Convertor and fuse panel
Thiss is offline   Reply With Quote
The Overlander :: 1964 Airstream Overlander Janet H Airstream Registry Discussions 3 08-20-2018 10:12 PM
Overlander Land Yacht International :: 1964 Airstream Overlander Land Yacht Internati overlander64 Airstream Registry Discussions 2 01-27-2018 06:28 AM
Land Yacht Overlander :: 1968 Airstream Overlander Von Moritz Airstream Registry Discussions 0 10-10-2013 08:29 AM
Overlander International :: 1973 Airstream Overlander rmoores Airstream Registry Discussions 0 01-31-2012 10:46 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
