Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1969 Overlander
Old 06-15-2002, 06:37 AM   #1
PeterH-79MH's Avatar
Profile:
Images: 63
weight specs for 68 Overlander 26D
dry weight is 4,170 lbs
tongue weight of 435 lbs.
GVWR add approximately 1,500 lbs to the dry weight.
PeterH-79MH is offline   Reply With Quote
Old 06-15-2002, 06:10 PM   #2
Rick's Avatar
Profile:
Hey Pete!
You would'nt happen to have the weight distribution would you? I'm completely rehabbing my '68, and want to make sure I get the weight proper in front of the axles. I am guesstimating 60% in front of the axles / 40% behind.
Any input? Thanks! Rick
Rick is offline   Reply With Quote
Old 06-16-2002, 09:21 AM   #3
Profile:  1996 30' Excella
Brighton , Michigan
The tongue weight should be 10% to 15% of the gross trailer weight with 12% considered ideal. In other words a loaded trailer weighing 6000 lbs. should have a tongue weight between 600 lbs and 900 lbs with 720 lbs recommended. Lighter than 10% will cause handling problems (sway) and greater than 15% will overload the hitch.
apple 1 is offline   Reply With Quote
Old 06-16-2002, 03:49 PM   #4
Rick's Avatar
Profile:
Thanks, Apple, but that's not exactly what I was referring too. Tongue weight I'm very familiar with - I used to work in a boatyard. I am looking for the total weight on front of the axles and behind the axles which indirectly accefts the tongue weight.
You could have 2000 lbs under the front window and have way too much tongue, while distributing the 2000 across 15' of trailer frame (before the axles) reduces the overall weight on the tongue. Then there's center of gravity, which is a whole other ball of wax, but we won't pursue that here.
Thanks for the reply, though!
Rick
Old 02-07-2003, 09:22 PM   #5
Martha's Avatar
Profile:
Images: 38
68 overlander
I just got a 68 overlander in pretty good condition...thankfully.
I am trying to "fix"/restore the storage cabinets under the twin bed (6 covers that push up). Is it possible to find the plastic that attached the front covers to the piece that pushes back???
Martha is offline   Reply With Quote
Old 02-08-2003, 03:49 PM   #6
Rick's Avatar
Profile:
Hey Martha,
Unless some good fellow has spares or you can find them in a market somewhere, probably not. You may be better off trying to adapt a different rolling mechanism, like that of a computer keyboard try, to the drawer lid(s). In this ongoing restoration which is taking forever, I am opting those drawers out to gain some valuable space for a larger bed set.
Good luck
Pingbacks are On
Tounge Weight?? 76 Overlander 27' tin can luv Airstream Trailer Forums 2 01-27-2004 12:44 PM
weight distributing bars/trunnion bars teutonik Hitches 2 12-04-2003 06:58 AM
Dry weight variances Moonshot On The Road... 1 09-11-2003 08:06 PM
Education on Sway & Weight Distribution John Our Community 7 01-28-2003 02:48 PM
71' Airstream Caravel 18' weight specs PeterH-79MH 1969-1971 Caravel 0 06-15-2002 06:28 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
