Old 10-06-2013, 01:54 PM   #1
1969 27' Overlander
Vestavia , Alabama
Replaced brake controller, need help with wiring
Swapping the corroded plug this afternoon on my TV and I don't think that the wires I have are correctly connected. I purchased new 7 pins for my TV and the pig tail.
I can't seem to find a diagram for this connector. It is a 3101 Signal-Stat which is what plugs in my Airstream.
Does anyone have a wiring diagram, or can tell me what each pin should be connected to? it has 3 connections on top, 3 in middle row, 1 on bottom.
Currently, L-R is TOP Yellow, Red, Green
Middle L-R, Blue, Black, Brown
Bottom = White
Aubiexx is offline   Reply With Quote
Old 10-06-2013, 02:09 PM   #2
SteveH's Avatar
Common Sense , Texas
This might help.
Regards,
Steve
Old 10-06-2013, 02:17 PM   #3
1969 27' Overlander
Vestavia , Alabama
Trying to attach images of what I am working with. Hope this works.
http://s23.postimg.org/hmxbordrv/photo.jpg
http://s12.postimg.org/a5l33qz6l/photo11.jpg
Old 10-06-2013, 02:34 PM   #4
2006 30' Classic
Milton , Florida
How to Install a New Plug
Bottom = White
Be very careful in what you do. Your trailer may not be wired according to the so called standard arrangements.
Create your own wiring diagram by identifying the color coding vs pin location on the original set up, then connect the new plug using the diagram that you previously created.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 10-06-2013, 02:39 PM   #5
1969 27' Overlander
Vestavia , Alabama
Thanks. Did you look at the pictures I just posted above?
Old 10-06-2013, 05:05 PM   #6
1969 27' Overlander
Vestavia , Alabama
I am pretty sure the wiring on my trailer or the umbilical cord is not standard. I guess I will be re-testing all the wires on the cord to make sure they are accurate.
Is there a best practice for doing this. I expect it will be easy to find the rt and lft blinkers, reverse, and clearance lights, but not necessarily the ground, electric brakes, and Aux power.
