Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 07-02-2016, 04:23 PM   #41
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Lucille is looking good and you are using it for memories.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-02-2016, 06:26 PM   #42
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
Hey is that a split AC on the tongue ?
truckasaurus is offline   Reply With Quote
Old 07-05-2016, 04:08 AM   #43
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
It's a Fujitzu 120v ductless split. It works really well.
Drabnormal is offline   Reply With Quote
Old 07-05-2016, 07:54 AM   #44
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Can you post a picture of the evaporator and fan assemble of that split system mounted in the trailer?
Old 07-06-2016, 04:09 AM   #45
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Name:	ImageUploadedByAirstream Forums1467798998.866998.jpg
I stil have to build a grille to put over it. Click image for larger version
Name:	ImageUploadedByAirstream Forums1467799085.710273.jpg
https://instagram.com/p/BAVk2vOzeib/
I build a "cribbing" to raise it off the tongue so I could still use the distribution bars. It's offset a little because of the wiring cap on the road side. Once the cover is built (happening right now) it'll look centred I'll post pics of that tonight.
Name:	ImageUploadedByAirstream Forums1467799500.189040.jpg
Name:	ImageUploadedByAirstream Forums1467799767.534649.jpg
Learning this rebuilding thing as I go. Family by my side the whole way.
1969 27' Overlander
2011 Ford F150 Ecoboost
Twitter - @mikep95
Instagram - @drabnormal
Old 07-06-2016, 04:18 AM   #46
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
The Instagram video doesn't seem to be working.
Name:	ImageUploadedByAirstream Forums1467800109.670946.jpg
Piece of plate anchored to the top of the window frame.
Pieces of angle bolted to the plate and to the reinforcements I fibreglassed to the inside cap
Back plate is mounted to the window frame plate.
Name:	ImageUploadedByAirstream Forums1467800296.977274.jpg
1969 27' Overlander
Twitter - @mikep95
Old 07-06-2016, 05:50 AM   #47
1960 33' Custom
Athens , Georgia
Cool and now I see spray foam insulation too! Can you post details of that too?
Old 07-06-2016, 05:59 AM   #48
1955 22' Safari
Laredo , Texas
Nice job
Was hoping to mount mine transversely like you did but there was not enough room on the tongue. I ended up removing one propane tank so I can still use the tongue jack. Love my mini split - quiet, efficient and economical!
ID:	266091   Click image for larger version
55AS is offline   Reply With Quote
Old 07-06-2016, 08:38 AM   #49
1962 28' Ambassador
Mesa , Arizona
Very nice ideas on the mini splits.
Hittenstiehl
Old 07-06-2016, 09:50 AM   #50
in the rising sun toaster
1956 26' Cruiser/Overlander
Wimberley , Texas
VERY nicely done - congrats on your obvious attention to fit and finish! Question about the undergirding of your tanks: These appear to be flat metal strap (what kind/quality?) w/ rubber/neoprene/? cushioning at the tank and the ends of strapping bolted to frame). I used a similar lash-up system when installing the blk and gry tanks ~30 years ago, but used SS chain threaded through heater hose as cushioning w/ end links of chains lock-nutted onto SS bolts mounted in the frame members. (And am *glad* I used SS way back when because it sure made for an easy/fast R&R for the cracked-beyond-repair blk tank several years back.)
rsjmcg is offline   Reply With Quote
Old 07-06-2016, 10:46 AM   #51
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
jealous of those split ac units. Wanted one for a long time. Still using a window unit in the front of our 66 when needed. Works great but makes sitting on the couch a bit chilly.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-07-2016, 04:03 AM   #52
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
There's not much to share on the spray foam. I had a local company come in and do it. They gave me about 1-1/2" on the walls and 3"under the floor.
Piece of advice...tuck tape all the ribs before you spray. Don't put it tight. The tape and overspray peel right off making cleanup super easy.
1969 27' Overlander
Twitter - @mikep95
Old 07-07-2016, 04:13 AM   #53
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
It's four straps of galvanized banding with a breaking strength of (I think) 150lbs. I checked at the time but can't remember. I then added some rubber mat to keep the bands from cutting through. I did all that before getting it spray foamed. I had to move one of the grey tanks about 1-1/2" because I miscalculated where the axle bracket would end up. Believe me that foam is helping to keep everything in place!
1969 27' Overlander
Twitter - @mikep95
Old 07-07-2016, 04:16 AM   #54
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Here's the cover I had made to protect everything as we travel. He even gave me a little zipper door to access the jack controls. It has two straps that go underneath to keep it in place. Click image for larger version
Name:	ImageUploadedByAirstream Forums1467886578.034343.jpg
1969 27' Overlander
Twitter - @mikep95
Full Time Streamer versus other full time RVs rodsterinfl Full-Timing 31 01-18-2016 05:31 PM
Parked with full hookups and full water tank question badkat Plumbing - Systems & Fixtures 16 10-18-2013 09:32 PM
1972 27' Full Floor Replacement InOverHeadVT Repairing/Replacing Floor &/or Frame 4 06-26-2010 10:52 AM
fuel gauge showing full when it is not full Normin storm Mechanics Corner - Engines, Transmission & More... 2 08-25-2009 09:31 AM
'68 Overlander Floor replacement HELP!! Aluminati Repairing/Replacing Floor &/or Frame 96 01-18-2008 10:24 PM
