Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 07-15-2014, 07:20 PM   #21
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
The lower was to provide a place to "spline" them together. Earlier trailers just butted them up on a cross member and those trailers all seem to have flooring cracks at those joints. As far as spanning that far, all I can imagine is the added weight might be an issue, particularly towards the extreme ends but maybe it isn't an issue.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 07-21-2014, 11:28 AM   #22
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Name:	ImageUploadedByAirstream Forums1405963660.977785.jpg
Here is the frame fresh from its sandblast/paint trip. Hope to start the cleanup in the rust spots when I get back to town on Friday.
Learning this rebuilding thing as I go. Family by my side the whole way.
1969 27' Overlander
2011 Ford F150 Ecoboost
Twitter - @mikep95
Instagram - mikep951
Drabnormal is offline   Reply With Quote
Old 07-27-2014, 07:12 AM   #23
KCN
KCN's Avatar
Victor , Idaho
I am using a VHB 3M double-sided bonding tape between the dissimilar metals. Comes in a variety of widths - the stuff is really strong though, so once it has a chance to bond it's pretty tough to remove. I'm also using it in areas where Airstream originally used Butyl tape. They used it as a sealant/moisture barrier though, not as a barrier to galvanic corrosion.
If you want more input and feedback etc.. ask the moderators to move your thread to the Overlander section. Seems to be where most of the full restoration threads are located.
Good luck with the restoration - looks like you are getting after it!
KCN is offline   Reply With Quote
Old 07-27-2014, 07:22 AM   #24
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Thanks KCN! I'm done all of the frame repairs and painted the spots with Epoxy yesterday. Now I'm waiting (impatiently) for the neighbourhood to wake up so I can rip sheets of plywood in my driveway and start on my floor. Click image for larger version
Name:	ImageUploadedByAirstream Forums1406467293.810236.jpg
ID:	217522Click image for larger version
Name:	ImageUploadedByAirstream Forums1406467311.899096.jpg
1969 27' Overlander
Twitter - @mikep95
Old 07-27-2014, 06:03 PM   #25
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
I've followed the direction from another post of leaving 1/4" of plywood overhanging the outriggers but what about at the door? The outriggers there seem to stick out further. I don't have the handle/plate that covers the step in yet so I haven't bolted down anything but the front most piece. I just don't want to get to the other end and find that I have to start all over again.
I'll be searching the forum tonight but any suggestions would be appreciated.
Thanks.
1969 27' Overlander
Twitter - @mikep95
Old 07-27-2014, 06:06 PM   #26
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Here's what I have
Name:	ImageUploadedByAirstream Forums1406505853.488543.jpg
First outrigger
Name:	ImageUploadedByAirstream Forums1406505918.582404.jpg
Hitch side of step
Name:	ImageUploadedByAirstream Forums1406505952.067843.jpg
Bumper side of step
1969 27' Overlander
Twitter - @mikep95
Name:	ImageUploadedByAirstream Forums1406505877.382338.jpg
Old 07-28-2014, 01:33 PM   #27
KCN
KCN's Avatar
Victor , Idaho
various outrigger lengths
This link http://www.airstream.com/wp-content/...41aa4eaa52.pdfwill take you to your original trailer specs. It indicates that your floor was 92" wide. Older ones like mine were 88 ish. The 1/4 inch overhang on the outriggers of my trailer may or may not be accurate for your vintage? If you have your original floor you can measure that to see what it was. I don't know why your step outriggers are longer than your other ones, but I bet if you email/PM either Frank Yesnan at Frank's Trailer Works or Colin Hyde they will have the info for you.
Kathy
Old 07-28-2014, 02:32 PM   #28
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
If it is the step then the door threshold will cover that, you need it!
Cliff
Yes I said that! Or did I?
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 08-05-2014, 05:09 AM   #29
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Pulled up the new floor when the levelling jacks I ordered came in faster than expected. I've installed them, welded in the new plate across the door opening, and am back at putting in the floor. Click image for larger version
Name:	ImageUploadedByAirstream Forums1407236925.282441.jpg
ID:	218332Click image for larger version
Name:	ImageUploadedByAirstream Forums1407236943.891839.jpg
Hope to put the shell back on soon!
1969 27' Overlander
Twitter - @mikep95
Old 08-28-2014, 08:14 PM   #30
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
It's official. I hate doing bearings.
Name:	ImageUploadedByAirstream Forums1409278450.316277.jpg
I've changed the bearings, races, and seals. I haven't done the brakes because I haven't sourced the replacement parts yet. I'm not worried because the wires are just dangling anyway.
What have you guys been doing about the original brakes and backing plates?
I'm on the fence. The originals are overbuilt and in great shape like everything else but it seems like the masses are just swapping out to a whole new setup. Are the new ones as good or better? Any feedback would be appreciated.
Also, I'm marrying the shell and frame back together this weekend. Any words of wisdom for this newbie?
1969 27' Overlander
Twitter - @mikep95
Old 08-29-2014, 06:51 AM   #31
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Replace the axles with complete new brakes.
Lance
Lance M is offline   Reply With Quote
Old 08-29-2014, 07:27 AM   #32
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Hi Top!
I've been contemplating that as I'm unsure of the bushings and all the other bits. Since the only original piece at this point is the frame and shell, it would provide piece of mind.
1969 27' Overlander
Twitter - @mikep95
Old 08-29-2014, 07:39 AM   #33
1981 31' Excella II
New Market , Alabama
Probably easier to do now you have everything apart.
Perry
Old 08-29-2014, 01:28 PM   #34
KCN
KCN's Avatar
Victor , Idaho
I did my axles first. Glad I did, but if I had it to do again, I would have ordered axles Dexter axles from my local trailer supplier and not had a third-party order Axis for me and pay all that extra freight.
Old 09-09-2014, 06:51 PM   #35
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
After a long separation, the top and bottom have settled their differences and decided to reunite! Click image for larger version
Name:	ImageUploadedByAirstream Forums1410309972.577411.jpg
ID:	221374Click image for larger version
Name:	ImageUploadedByAirstream Forums1410310031.260200.jpg
ID:	221375I'm pretty sure I'm going to follow your advice and swap the complete axles.
Wait until I upload the pics of what I'm going to attempt this weekend....
Hint: it's the only way I can keep working on 'ol Lucille over the winter. I'm busy for the next three weekends so I only have this Sunday.
Keep your fingers crossed boys and girls.
1969 27' Overlander
Twitter - @mikep95
Old 09-14-2014, 06:40 PM   #36
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Here's how today's efforts turned out. I'll start on the wiring next week. Click image for larger version
Name:	ImageUploadedByAirstream Forums1410741006.627233.jpg
ID:	221874Click image for larger version
Name:	ImageUploadedByAirstream Forums1410741072.527021.jpg
1969 27' Overlander
Twitter - @mikep95
Old 09-14-2014, 07:26 PM   #37
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
Hi Drabnormal,
That is one pristine frame. Solid base to work with. Body looks clean, too. I agree with Top and other to replace the axles. I'm told the rubber in the tubes gets stiff and could promote rivet pop! Love the garage! I need one of those. You're neighbor is going to eat his words. Looks like you don't have a problem with trailer restrictions in your neighborhood.
surfpod is offline   Reply With Quote
Old 09-15-2014, 08:46 PM   #38
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Hi Surfpod.
When I brought the rig home it had a vibration just below highway speed. I figured it was the tires. Changed those and the bearings but it was still there as I was towing the frame/floor out to where I stored the shell. When I put the shell back on and drove it home I actually popped a few of the short rivets that tie the floor to the frame.
Definitely going to change the whole axle. Thank you for the input. I don't like the idea of things rattling themselves apart.
1969 27' Overlander
Twitter - @mikep95
Old 07-02-2016, 05:42 AM   #39
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Well...I guess I haven't been keeping up with this post as diligently as I should have.
I'm laying on my bed in the 90% completed trailer typing this. We're in a provincial park and the rest of my family is still sleeping. We use it every weekend and I continue to work on it throughout the week.
Let me see if I can get a few pictures uploaded before everyone wakes up.
Old 07-02-2016, 05:53 AM   #40
Drabnormal's Avatar
1969 27' Overlander
Sudbury , Ontario
Name:	ImageUploadedByAirstream Forums1467459954.693429.jpg
ID:	265721Click image for larger version
Name:	ImageUploadedByAirstream Forums1467459988.359263.jpg
ID:	265722Click image for larger version
Name:	ImageUploadedByAirstream Forums1467460024.989456.jpg
ID:	265723Click image for larger version
Name:	ImageUploadedByAirstream Forums1467460062.243794.jpg
ID:	265724Click image for larger version
Name:	ImageUploadedByAirstream Forums1467460103.765039.jpg
ID:	265725Click image for larger version
Name:	ImageUploadedByAirstream Forums1467460228.110049.jpg
ID:	265726Click image for larger version
Name:	ImageUploadedByAirstream Forums1467460297.795132.jpg
ID:	265727Click image for larger version
Name:	ImageUploadedByAirstream Forums1467460329.969464.jpg
ID:	265728Click image for larger version
Name:	ImageUploadedByAirstream Forums1467460363.096481.jpg
ID:	265729Click image for larger version
Name:	ImageUploadedByAirstream Forums1467460383.288269.jpg
1969 27' Overlander
Twitter - @mikep95
Instagram - @drabnormal
Full Time Streamer versus other full time RVs rodsterinfl Full-Timing 31 01-18-2016 05:31 PM
Parked with full hookups and full water tank question badkat Plumbing - Systems & Fixtures 16 10-18-2013 09:32 PM
1972 27' Full Floor Replacement InOverHeadVT Repairing/Replacing Floor &/or Frame 4 06-26-2010 10:52 AM
fuel gauge showing full when it is not full Normin storm Mechanics Corner - Engines, Transmission & More... 2 08-25-2009 09:31 AM
'68 Overlander Floor replacement HELP!! Aluminati Repairing/Replacing Floor &/or Frame 96 01-18-2008 10:24 PM
