Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1969 Overlander
Old 05-16-2003, 09:28 PM   #1
Profile:
Lightbulb '69 Overlander breakfast nook
Hi! We have a '69 Overlander. In the front of it there is currently nothing. We would like to put in a breakfast nook like the orgional. I can only find the measurements for the couch and not the nook.....does anyone have any ideas of where I could get the measurements at?? Or does anyone have one that has some really good pictures???? I have been told that any of the Airstreams from 1967-1974 would be the same measurments.....does anyone know if this is true???? Please e-mail me at CountryLogCabin@aol.com.
Thank You!
Kammy
CountryLogCabin is offline   Reply With Quote
Old 05-18-2003, 09:25 AM   #2
Profile:
breakfast nook?
I, too, have a 69 Overlander. In the salon there is a couch and a table that folds against the wall. Is the table what you are wanting measurements of? Or what? I would be happy to go measure if I knew what you wanted.
Mikie is offline   Reply With Quote
Old 05-19-2003, 08:48 AM   #3
Profile:
Arrow About breakfast nook
Hi! That is nice of you to offer.........I have seen the front done in two ways....the couch and then a breakfast nook........it is where there are seats on both sides and a table in the middle.....that is what I would like to verses the couch......do you know where I could find the measurements for that?
Kammy
Old 05-17-2005, 02:21 PM   #4
Profile:
Check Mine Out
I am in the process of having a dinette built in my '69 Overlander. Check out the photos:
http://homepage.mac.com/theridleys/PhotoAlbum2.html
When I bought it there was nothing up front. It extends from the kittchen to the door.
Bren
69OverInt is offline   Reply With Quote
Old 05-17-2005, 02:26 PM   #5
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
Looking good - Keep us posted!
77 Argosy Minuet, 6 metre
77 Argosy 24, Rear door
AIR 3181, WBCCI/VAC # 5575
What if the Hokey-Pokey is really what it's all about?
Janet is offline   Reply With Quote
Old 05-17-2005, 03:14 PM   #6
Uberlanders's Avatar
Profile:  1968 26' Overlander
Wenatchee WA , Cape Cod
Ours is an original dinette. But no human over 4 foot could sleep in the two single bed it forms. We are considering changing it to a gaucho so a real person could actually use it.
See our photo gallery on our website for pictures of the dinette.
Jim & Kathleen
1968 Overlander - WBCCI #5793
Uberlanders is offline   Reply With Quote
Old 05-17-2005, 03:25 PM   #7
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
I used these plans for a reference. But my measurments were customized for my coach.
http://globetrotter64.home.att.net/project2.htm
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 05-17-2005, 04:59 PM   #8
LADYBUG
GT1963's Avatar
Profile:  1963 19' Globetrotter
Lakefield , ON
Images: 59
Hi Kammy;
We have a 21 ' 1969 Globe Trotter - with the original "Breakfast Nook" as you refere to - also known as the dinette.
We may have a small coach but the singles the nook make up are 6'4" and just under 30" wide. Although the one side is shorter - the end side panel flips up and there is a filler cushion that makes up the difference - even when flipped up there is still room to squeeze by out the door in emergencies.
We thought of making the "Sliders" on either side to slide out to the middle making a large double - but for what it is worth - we can have that in the back! of our GT
Hubby is 6.2 and he slept on the short side (hmm cause I refused to sleep right by the door - especially since our door lock did not work then!)
I will go out and take measurements and pics of the singles if you like - or you could check out our Photo Album - GT6921 - on the Photo forum.
Good luck with your search - ps you wouldn't happen to have a spare left front wing window would you? Trade you a boot mat for yours
Streaming in the spirit of Exploration...
"To go places and do things that have never
been done before-that's what living is all about."
- M. Collins
Peter & Sharon
WBCCI #1963 & 1961
GT1963 is offline   Reply With Quote
Old 05-17-2005, 05:51 PM   #9
LADYBUG
GT1963's Avatar
Lakefield , ON
Images: 59
Hi me again;
Okay no measurements yet but here are some pics as I realized I never took any of the curbside single made up.
A couple of design notes - this is factory original - we have seen this side panel also as a slide out section rather than the flip up style. The square flat leg you see that rests on the ground - is what flips down on a loaded spring and slides back up to form a V in the hollow you see in one of the pics. The panel is then held in place by the infamous white latch - which cost an arm and a leg if you break them.
Also note that we have not finished the restoration and the back rest has not been re-attached to its original position. The short back rest does not sit along the side of the wall as pictured (however it is much mor comfortable and warmer!) it is actually hinged to the wood panel mounted on the wall - there is a snap that holds that panel up and snaps to a snap on the under side of the oval window.
Lastly the filler cushion is stored in the shelf behind the table and the table is usually in its full down position but can also be left part way up as well. The filler cushion is snaped to two snaps that were screwed into the base bench pictured with two blue strapes - that replaced the original hard clear plastic strapes. You can sleep either way head to front or head to back.
The other single is pictured left in Couch/Nook mode. We added the big cushions because well the factory back rest would give you a major back ache in about 3 seconds. And for short legged people the bench is pretty wide so the fancy cushions really came in handy.
You can also see by the door picture that there is plenty of room to get by and out the door if need be.
We only slept in the singles twice and they were the best nights sleep we had - as neither of us had to share the bed with the dogs
Hope these help..if you want measurements let me know.
PS Janet how do you like this pre 70's fabric - kinda cool really but they are tired and we will be continuing to reupholster them with the blue suede.
ID:	12221  Click image for larger version
ID:	12223  Click image for larger version
Name:	Single Panel 1.jpg
Name:	Single Panel2.jpg
ID:	12231  Click image for larger version
Name:	Singles at Breakfast nook.jpg
Name:	Single Entrance Space.jpg
- M. Collins
Peter & Sharon
WBCCI #1963 & 1961
Old 05-17-2005, 06:08 PM   #10
Janet's Avatar
Images: 63
Originally Posted by GT6921
....PS Janet how do you like this pre 70's fabric - kinda cool really but they are tired and we will be continuing to reupholster them with the blue suede.
I like it! In a non-organic kinda way, after all it's not orange or lime green..
I'm fairly certain that touquise is on it's way back in - maybe it'll show up in next years CCD?
Old 05-17-2005, 06:49 PM   #11
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 92
Just a thought...
Are you sure that it's not meant to have the table drop down with cushions on top to make into a near double turned 90-degrees? That's how we designed our dinette...it works great!
Dinette
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
InsideOut is online now   Reply With Quote
Old 05-17-2005, 09:32 PM   #12
Dasterdly Dinette
That is what is weird about this trailer. The dinette is original but it folds into two singles. Being the expert camper girl I swore to my husband that somehow the chairs pulled together and the extra pads, stashed under the table, fit between the two sides to form a double. We bumped around for at least 45 minutes. We realized that the pads pull down, and you pull the seat boards out, but they do not meet in the middle. That only formed part of the beds. The table folds up toward the window, not down toward the bed, to make a bridge to form a double. And the end caps of the dinette seats come out, with folded wood frames, they accordian under the seat when not pulled out. The extra pads fit in this new open space forming two single beds. Instead of the seats sitting flat they are tipped back toward the window, so they never lay flat when down. I will try to post a picture, tomorrow when I have the camera at home.
Kathleen
Jim & Kathleen
Old 05-17-2005, 09:45 PM   #13
InsideOut's Avatar
1956 22' Safari
Images: 92
Who said it was ever 'out'?
Shari
Old 05-18-2005, 06:34 AM   #14
LADYBUG
GT1963's Avatar
Lakefield , ON
Images: 59
Shari
You are right Shari - of all the wacky colour Torq, Yellow & Orange The Torq has been maintained for years - but the Yellow and Orange have never dared to stand alone since the 60's But like everything it comes in cycles.
It is the Baby Boomers faults I think - we long for the younger days - so we bring back some of the fashions that we just missed or could not afford when we were kids and today as adults with kids brains we can do anything we want.
Then again - it could be the generations behind us that are just too busy to invent new and innovative ideas - so they go into the history books and recycle what was successful and hope to make a book on someone elses ideas - cause that is what we have taught them - to recycle
- M. Collins
Peter & Sharon
WBCCI #1963 & 1961
Pingbacks are On
69 Overlander Potable tank Lee Pace Dehumidifiers & Ozone Generators 8 11-24-2003 08:21 PM
NO 71' overlander in the list ? brunoffrance Airstream Trailer Forums 2 06-20-2003 09:53 AM
A/C Install for 1955 Overlander Tinovations Furnaces, Heaters, Fireplaces & Air Conditioning 10 02-23-2003 11:18 PM
wanted key blank for 69 Overlander bgow 1969 Overlander 1 10-02-2002 10:44 AM
tree on 69 Overlander pebblepoint General Repair Forum 2 09-10-2002 06:01 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
