I just had these thoughts
singles to a double in the front - now lets see.....
breakfast in bed - as it should be with a table that does not tip on you....
company coming you can have a nap and have the table all set - but that might be a bit hard if you are napping on it...
With singles one of you does not have to be an acrobat to crawl over top.
....cuddling......well think about it - how much space do you take up when you cuddle? - and how much space is required and for how long on the uh well it would be sensored
....and kids that usually result from the above - will fight like tooth and nail if in the double but singles are perfect.....
....and there is room for the pets on the floor inbetween the singles - and if you are desparate for room - you could shore up the table with two legs and throw a sponge and sleeping bag up there for the friend met at the campsite.
So anyone building a dinette - It might be a good idea to have it versatile - like the short end by the door can be build with the original "Sliders" to pull out lenght ways too - that way you would have a choice of 2 single - but it PizzaChops case 3 singles or a KING bed for 5 tee hee.
