Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1969 Overlander
Old 06-13-2009, 11:01 AM   #1
sbreide471's Avatar
Profile:  1969 27' Overlander
woodinville , Washington
Cool 69 27ft overlander
does anybody know the wiring diagram on the trailer plug or were to get the femail plug that gos to the trailer frome the truck for a 69 overlander 27ft im trying to restore it and does the wheels stop when you back up or does the break wire need to be pulled in order to back up
thanks scott
sbreide471 is offline   Reply With Quote
Old 08-27-2009, 08:48 AM   #2
Billings , Montana
seven way wire diagram
I found this7wayplug1966-81.pdf
gentryBC is offline   Reply With Quote
Old 08-27-2009, 10:30 AM   #3
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
this may help Replacing 7-Pin Connector
or this 1975 Electrical Diagrams. Look at the 7-way connector diagram, second set of graphics down the post. It will tell you the difference from the standard modern tow vehicle pin-out to the Airstream pin-out.
Zep
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com
Old 08-29-2009, 09:35 PM   #4
mbmbstreamer's Avatar
Profile:  2006 25' Safari SS SE
1969 27' Overlander
Martinez , Georgia
I just replaced my umbilical and female connector in the wall of my 69 Overlander. I replaced the wall connector with a metal female round pin connector made by Pollak. It fit the holes identically and I wired it identically with OEM.
I modified the umbillical wiring by connecting the appropriate wire (regardless of color) to the applicable pin. I had the black wire (from the truck) in the center - charge line. I connected the blue line from the truck to the yellow wire on the trailer and the yellow wire from the truck to the black on the trailer.
I made a diagram and matched the truck connector to the trailer. The metal Pollak female plug looks great, but I did put a sheet of gasket (rubber) between it and the aluminum skin. I also used stainless screws. Make sure you take careful notes before disassembling and don't lose any grounds. There are several connected to the back side on each of the mounting screws.
mbmbstreamer is offline   Reply With Quote
27ft model questions Bluto 2007 Classic (all lengths) 4 04-11-2009 02:00 PM
75 27ft International Questions pixiehat Vintage Kin 0 11-23-2008 07:35 PM
1975 0wner's Manual 27ft Overlander Land Yacht creelcamping 1975 Overlander 4 09-08-2008 08:42 AM
1975 27ft Overlander-Any concerns or problem areas? PICS LAWFISH 1975 Overlander 14 02-26-2008 06:17 PM
Any 27ft '82 Excellas out there? kbodoh 1981 - 1983 Excella 5 08-08-2007 08:32 PM
