Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1969 Overlander
Prev Previous Post   Next Post Next
Old 08-29-2009, 09:35 PM   #4
mbmbstreamer's Avatar
Profile:  2006 25' Safari SS SE
1969 27' Overlander
Martinez , Georgia
I just replaced my umbilical and female connector in the wall of my 69 Overlander. I replaced the wall connector with a metal female round pin connector made by Pollak. It fit the holes identically and I wired it identically with OEM.
I modified the umbillical wiring by connecting the appropriate wire (regardless of color) to the applicable pin. I had the black wire (from the truck) in the center - charge line. I connected the blue line from the truck to the yellow wire on the trailer and the yellow wire from the truck to the black on the trailer.
I made a diagram and matched the truck connector to the trailer. The metal Pollak female plug looks great, but I did put a sheet of gasket (rubber) between it and the aluminum skin. I also used stainless screws. Make sure you take careful notes before disassembling and don't lose any grounds. There are several connected to the back side on each of the mounting screws.
mbmbstreamer is offline   Reply With Quote
27ft model questions Bluto 2007 Classic (all lengths) 4 04-11-2009 02:00 PM
75 27ft International Questions pixiehat Vintage Kin 0 11-23-2008 07:35 PM
1975 0wner's Manual 27ft Overlander Land Yacht creelcamping 1975 Overlander 4 09-08-2008 08:42 AM
1975 27ft Overlander-Any concerns or problem areas? PICS LAWFISH 1975 Overlander 14 02-26-2008 06:17 PM
Any 27ft '82 Excellas out there? kbodoh 1981 - 1983 Excella 5 08-08-2007 08:32 PM
