Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 01-29-2011, 10:41 PM   #41
1966 26' Overlander
Bluffton , South Carolina
i think the switch is for the water pump. haven't gotten to that yet. pump is still covered in funk. i learned this evening. I'm missing a few pieces from water system. check valve, regulator, and pressure relief have been removed. Just more to go on fix list.
teufel is offline   Reply With Quote
Old 02-01-2011, 07:44 PM   #42
1966 26' Overlander
Goodies from inland arrived. repaired and installed 7 window latches. Making more dowel nuts this weekend if I don't drive home.
Berth and bath scrubbed clean.
Need to rewire furnace thermostat. Rats ate wires at one point. Furnace needs to be removed to clean. Overhead storage street side needs to be rebuilt. Previous water damage from vent took its toll. Hung bunk in bracket and bottom fell out near vent.
Beds should be here soon.
Old 02-10-2011, 11:12 PM   #43
1966 26' Overlander
Bed arrived. Comfy but the glue fumes are killer. Hopefully it'll air out over next few days. Took a while for bed to ship but arrived two days later.
Old 02-19-2011, 10:25 PM   #44
1966 26' Overlander
Sprung a leak. Main line in front of toilet split. PEX conversion sooner than expected.
Also found leak at this valve/ regulator. What exactly is its purpose. Is it necessary? It was covered in expanding foam by PO. One line is supply and the other feeds spray nozel and main line for toilet. It's mounted in bottom of medicine cabinet.
ID:	122621   Click image for larger version
Old 04-24-2011, 03:12 PM   #45
1966 26' Overlander
Not much time to work on overlander. I made some minor progress over past few weeks. AC is running strong, repaired galley sink, replaced water lines, and rebuilt shower faucet. So far no more plumbing leaks.
Pics are in this order:
1. Sloan valve mentioned in last post. It seems to be an old vented float valve. it allows toilet to fill when flushed. it wouldn't seal so i replaced with a 1/4 turn cut off valve.
2. pic of rear plumbing as it sits today. will replace hot line soon. picked up red pex today.
3. Info card on parts used to rebuild shower faucet cartridge. 3 box stores did not have the cartridge in stock. None of box stores had the cartridge. They all had orings and flat washers.
Cold showers until i finish gas lines. Looking more like a camper every day. No more glorified tent camping.
ID:	128020   Click image for larger version
1966 overlander
1977 Minuet is mine! pattyo All Argosy Trailers 18 06-27-2006 10:09 AM
Make mine dull aluminum markdoane Cleaning, Stripping & Polishing 39 10-25-2004 10:38 AM
I'll Show you Mine If you'll show Me yours... joossens Link Archive 0 05-12-2004 12:51 AM
Axles, how do I know if mine are bad? nds Axles 16 12-19-2003 02:32 AM
Maybe I should tell you more about this lil "home" of mine ladyvain730 Our Community 3 05-01-2003 10:10 PM
