Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1966 Overlander
Old 11-17-2003, 10:39 PM   #1
McMullen
Profile:
Rewire with Copper
I wonder if anyone has tried to rewire with copper wire. I've taken down all my lights and about half wear severly coroded. I am planing on checking all the circiut with a circiut tester and then trying to pill the aluminum wire out after atatching a copper wire to it. Just Hoping someone had done that already. Mac
McMullen is offline   Reply With Quote
Old 11-18-2003, 06:05 AM   #2
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 144
I may be the bearer of bad news. Only from my experience with the '87, I don't think you will be able to fish the wires.
Lots of tight bends through ungrommeted small holes, plus, my wire bundles were tie wrapped at various points.
You may want to do a search on "rebuild" or "interior gutted" with the year added close to your trailer. Several forum members have removed interior walls and have documented the pictures for the benefit of the forum members.
A picture is worth a thousand words when it comes to understanding the interior construction and wiring of these units.
Dennis
WBCCI # 1113
AirForums #1737
Old 11-18-2003, 10:03 AM   #3
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
wire
I have aluminum wiring in my 67 Tradewind and am following the procedure for splicing in copper pigtails to the aluminum wire and coating with dielectic goop. There's several websites that detail the procedure. Do if for the lights and outlets.
"would you rather have a mansion full of money or a trailer full of love?"
Warning: (20%)
Tin Hut is offline   Reply With Quote
Old 11-18-2003, 02:27 PM   #4
McMullen
Profile:
Thank You both for your prompt replys. I will do the same with the gray goop and the copper. I do have plenty of aluminum to atatch to. Much easier in the long run even though it goes against my grain. Cheers Mac
Old 11-18-2003, 03:08 PM   #5
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Which years have copper wire and which years have aluminum wiring, and are both 12 volt and 110volt aluminum or?
Aaron
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 12:03 PM
replace old copper water lines with plastic pipes m. Clarke All Argosy Trailers 7 03-26-2004 11:42 PM
Copper and aluminum?!?!!? till Electrical - Systems, Generators, Batteries & Solar 4 02-11-2004 07:39 AM
Copper Canyon (Barranca del Cobre) Pahaska On The Road... 0 07-25-2002 07:14 PM
Replace copper water lines in 61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
