Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 03-06-2017, 02:34 PM   #1
ChuckZ's Avatar
1966 26' Overlander
2012 28' Flying Cloud
Waukesha , Wisconsin
Reattach skin
We were coming home to Wisconsin from a month in Florida & Georgia and I noticed that one of the panels attaching the side skin to the belly pan had come loose. After closer inspection it would appear that this is not the first time this panel had done this. Before I start pop riveting it back in place, can y'all suggest a better repair? (please don't say skin off cause it ain't gonna happen at this point in my life)
Name:	Belly panel.jpg
ChuckZ is offline   Reply With Quote
Old 03-06-2017, 03:12 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Looks like the rivet heads are still on the aluminum, so are they pulling out of the frame by the shank? What does the frame look like where this piece attaches? You may just need to size up your rivets, maybe install a few extras in new holes. But this might be a symptom of your frame rusting. Need to get under there and look at the frame.
TheGreatleys is offline   Reply With Quote
Old 03-06-2017, 05:29 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Use rivets with wide heads
Old 03-07-2017, 01:49 PM   #4
ChuckZ's Avatar
1966 26' Overlander
Thanks for the tip. I did take a look and it hasn't pulled away from the frame. Just from the belly pan. Frame appears to be fine.
Old 03-07-2017, 02:08 PM   #5
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
as Lumatic said use wide rivits.
These can be installed with a regular pop rivet gun. I carry a few in the tool box for emergencies. Available at Vintage Trailer supply and other places.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 03-14-2017, 09:25 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
this is common when the skin shakes and rattles down the road. You can use those wide rivets and add some washer to them if you like.. A bead of sealant at the seam is good too.
While you have it open you might ( if you have not yet) wire brush and rustproof the frame.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Reattach body trim chaimemet General Repair Forum 3 07-02-2012 04:47 AM
interior skin scrap for exterior skin patch? whatsherface Ribs, Skins & Rivets 1 06-12-2010 07:56 AM
How to reattach hinge for hehr vent operator glang58 Roof Vents, Skylights & Fans 1 06-07-2010 03:34 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 02:54 PM
