Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 12-01-2014, 03:40 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Overlander : Have u moved your table?
Ou r dinette table mounts right inside the trailer near the door. It slides in along the gaucho. When unfolded and the leaf is in, it is kinda tight to slide in behind it on the gaucho.
It could easily be moved across to the street side, but not sure how much difference that would make. Seems a screwy design, but it is in great shape so I don't want to replace it.
Anyone moved theirs?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-01-2014, 03:54 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
see it on the curb side? I guess moving it would not be as easy as I thought now looking at the shelf above it. It curves the wrong direction.
AIR #005
retired!
Old 12-02-2014, 05:56 AM   #3
KAYAKAMPERS's Avatar
1999 27' Safari
Stone Mountain , Georgia
Alan, What I did is modify the table ( made it narrower ) so when it is out it doesn't intrude into the doorway. It is still wide enough to fit 4 people around it, but it can be opened and not be in the way. I built a cushion back on the other side and have two short stools to turn the coucho into an "L" shaped couch. I'll send pics soon, but we like the way it works.
_______________________________
Beth Wallace & Chris Sanor
1999 Safari 27'
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
KAYAKAMPERS is offline   Reply With Quote
Old 12-02-2014, 07:57 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
sounds good. Not sure i want to change the table though. we do have two of those vintage folding chairs that we use as well.
AIR #005
retired!
Old 12-02-2014, 05:50 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
AlanSD, I have the same thought as you. I don't care for the fold up table in front of the door. The 66 Trade Wind has the same table arrangement as your Overlander. My 86 has a fold up table on the street side. The tables mount under the shelf. I think a little shelf like that on the street side would be fine. I think folding chairs are necessary to best utilize the table for a little dinner. Sitting on the edge of the gaucho isn't the most comfortable.
It won't be too long before I can answer yes to your thread question.
David
Old 12-03-2014, 05:10 PM   #6
1999 27' Safari
OK, so here is what I did. I kept the table in the same location, but made it narrower so that it doesn't intrude into the doorway but is still usable for four people. I also modified the leaf and it now works great. Click image for larger version
Name:	New table.jpg
Name:	Modified table.jpg
I cut the table down about 6" if I recall and sanded and stained the edge since it doesn't have laminate on it any more. On the other side of the trailer, we upholstered a back rest and attached it ( it's removable ) to a bracket on the wall. We purchased two stools ( Target ) and re upholstered the top by adding more foam and matching upholstery to the goucho. These, of course are also removable, but ads a bit more seating and storage to the front room.
1999 Safari 27'
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 12-03-2014, 05:15 PM   #7
1999 27' Safari
Looking at your table Alan, I remember how big it was. I may have taken off about 8". The reason we did not move it to the other side ( besides loosing any possibility of other seating ), we did not want to loose the use of the fold up table behind the cook top.
Chris
1999 Safari 27'
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 12-03-2014, 07:25 PM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Kayakampers... I like your modification of the flip up table. Yes, my 66 has a pretty big table and when I get seating room between the gaucho and the table, I'm half way into the door way. I also need the flip up counter space extender on the street side.
And your little stools are cool! They work as foot rests, and they work for seating on the opposite side of the table.
Clever thinking.
David
Old 12-04-2014, 05:58 AM   #9
1999 27' Safari
Thanks David, the stools are very useful. They have great storage, they make great foot stools when relaxing and I usually use one at the table on the door side. When positioned right ( out from the wall ) they are pretty comfortable with the back rest. We made the back rest a little wider so you can spread them out a little. With the counter extension down, two adults can sit side by side comfortably...as long as they are friends.
Chris
1999 Safari 27'
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 12-04-2014, 03:10 PM   #10
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I have the same table in my 65 overlander , the leaf is stored next to the table, is that where it's supposed to go? It's just slid in next to it. This has always bugged me, just doesn't seem right! Thanks, Brian
Cochese is offline   Reply With Quote
Old 12-04-2014, 06:58 PM   #11
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
The table leaf just sits behind the folded down table on my 66 Trade Wind. I'll try to remember a photo or two this weekend.
David
Old 12-04-2014, 07:02 PM   #12
1999 27' Safari
The leaf in our '66 does fit behind the table when it is down. On ours, there are two clips on the wall that the leaf tabs fit into so it is secure. Does your leaf and wall have those?
1999 Safari 27'
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 12-05-2014, 06:33 AM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
yes the leaf secures nicely to the wall. Its all so oringinal I am hesitant to change anything.
Did you do axles yet?
AIR #005
retired!
Old 12-05-2014, 06:34 AM   #14
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Chris
fold up table ? I don't have one of those behind the cook top area
AIR #005
retired!
Old 12-05-2014, 02:45 PM   #15
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I've tried to fit it between table& wall, can't seem to figure it out! Picture would be great...
Old 12-05-2014, 04:05 PM   #16
1999 27' Safari
I'm not sure Alan, but it may have only been available on the International models. I said "fold up" table, but I am talking about the drop leaf that, when up is an extension of the counter top behind the three burner cook top. A collapsible hinge and it folds down in front the the cabinet doors under the cook top in the living area.
1999 Safari 27'
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 12-05-2014, 07:35 PM   #17
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Here is a photo of the countertop extension that folds down when not in use. It might get in the way of another folding table on the street side. The extension is folded down in this view. You can imagine the arc of the counter as it swings up. It is in front of the window. I'll take more photos of my curb side folding table this weekend.
You folks might invent a handier way to make a "breakfast nook" out of my front gaucho.
David
Name:	1310 Galley.jpg
Old 12-05-2014, 08:12 PM   #18
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Can I get a pic of the stowed dining table leaf? My extra leaf is currently between the gaucho & table, this can't be right?!
Old 12-06-2014, 05:07 AM   #19
1999 27' Safari
Not yet Alan, Probably next year.....I am waiting for Rob's help . Actually, I want to help him on their Safari and I can get an idea what is needed. I am going to need them done eventually though, but they are OK for now. Everything rides well.
1999 Safari 27'
Tin Can Tourist
TAC #GA-27
AIR #34930
Old 12-06-2014, 05:10 AM   #20
1999 27' Safari
I will try to get one to you later today Cochese. It is raining a lot here now, but later when it lets up. I have the table out and can get a couple of good shots of the leaf and the brackets.
1999 Safari 27'
Tin Can Tourist
TAC #GA-27
AIR #34930
1985 Excella credenza, fold out table, little shelf that goes on top of the credenza, table next to the front door, chairs janeinthemtns Airstream Classifieds 0 10-12-2014 10:37 AM
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
falling table leaf of credenza fold-away table Fenghuang Cabinets, Counter Tops & Furnishings 3 02-13-2007 10:27 AM
Why Lock Moved Threads ???? hex Forum Admin, News and Member Account Info 4 10-28-2002 06:07 PM
moved and tore loose what happened overlander General Interior Topics 5 09-24-2002 06:50 PM
