Join Airstream Forums Today
Old 01-05-2012, 04:24 PM   #1
livinlightly's Avatar
1966 26' Overlander
Coeur d'Alene , Idaho
Home Sweet Airstream! 1966 26’ Overlander
* Greetings Airstream community!
My wife and I recently purchased our first Airstream a 1966 26’ Overlander. The trailer appears to be in good shape but I am prepared for the worst.
We looked a quite a few trailers and this one was by far in the best shape for the price.
We have big plans for our little trailer…
Over the next 10 months we are going to remodel the Land Yacht, sell the majority of our possessions and move in. While there are many reasons for this transition the main two are a simple lifestyle and better stewardship (time, talents & treasure) for God.
While I am pretty handy and love DIY projects, I am a completely green when it comes to large travel trailers. Last summer I took on a homebuilt 4’x8’ teardrop trailer and attempted to finish it in 2 weeks. In the end it took a bit longer than 2 weeks and because I was so ambitious I did not take the time to learn from others and ask questions. This became a nightmare as I battled leaks!
I hope to forego some unneeded headaches by gaining some knowledge and feedback from this community. I have spent lots of time lurking through these forums and have learned a lot. As I embark on this adventure I am looking forward to sharing my progress and learning from all of you!
Before I get into demolition here is our Land Yacht’s before pictures (and a few pictures of our Teardrop Trailer)
More posts & questions to come...I only have 10 months!
My beautiful wife showing off the sweet decor that came with the trailer.
livinlightly is offline   Reply With Quote
Old 01-05-2012, 04:42 PM   #2
Someone has changed out the AC.
There has been some metal replaced at the bootom of the door and forward of that.
You should check the axles out as the rubber rods look like they may have given out.
The Dura-Torque Axle
Check all the exterior gaskets. If they are original, they will all be hardened as sort of useless.
The beginning of your overhaul, would be to make the trailer totally waterproofed
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 01-05-2012, 05:37 PM   #3
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
Images: 14
Welcome
Good luck to you and yours. This is a great place to find everything you will need to complete your AS.
Take care Jim
WBCCI #2601 Den-CO Unit
AIR # 56543 TAC# CO-10
StreamRollin is online now   Reply With Quote
Old 01-05-2012, 06:48 PM   #4
rideair's Avatar
Congrats!!
Congrats! You picked a very good year for Airstream trailers, I should know, I have three 1966 Airstreams (Globetrotter, Safari, Overlander). 1966 was the first year for the “frameless” window which gives the trailer a great streamlined look though much caution must be taken with them for that very reason. Never ever leave the windows up on a windy day if you plan to leave the trailer for a long time. You may come back to broken glass. The main problem I’ve seen in the 1966’s is the floor around the toilet area seams to rot on all of them unless you got a mid-west trailer where it’s dry most of the time.
Andy’s right, fix the leaks first! I would not be to fast to tear the whole thing apart. That trailer is a very livable trailer the way it was designed as long as everything works. You will find you can leave the bed out in the back and still have plenty of room to get by, get in the closet, cabinets, etc… in the rear except for the three cabinets under the bed (of which one of those you can get to from the outside if you need too). The original frig was gas/elec (110v) Dometic M52 series and the heating system (looks to be original) had a cold air return system built in. You will need new axle’s which can be done in one day for about 1,500 bucks. I suggest going with the “original” axle pitch 22.5 degree’s with 7.00x15 bias-ply tires. There was a repair done on the front passenger side (again no big deal). You don’t show a picture of the street side to know if you still have the original Bowen hot water heater. If you do great, if you decide to replace (I’m interested in the complete outside cover if you change it out). Many folks will say, “Replace it now before it breaks at a bad time”. I personally have never heard of anything breaking at a good time! If it works, use it. If it does not, replace/repair it.
Many folks will say the original toilet can not be fixed, though many have been fixed by people willing to think outside the box, make parts, etc… Again, it’s a great design (I personally hate looking at a toilet) don’t fix something if it works! To save on water, use the spray (the toilet bowl water supply can be turned off from the back hatch)
Make sure the vent caps on top (3 of them) have not dry rotted and allowing water to go down the side of the pipe rotting the floor below as well as the refrigerator vent.
I think it’s possible the cushions could be original based on the one picture that shows a small piece of white cloth on the left side (I bet it has a snap that holds it in place) if so, I don’t think many would put that back when the recover which makes it a good chance it’s original. I’ll have to look at my sales info to see if it has a picture like it. The curtains are not. If you want to know how the originals were made let me know.
Again, the 1966 Overlander was one of the best trailers made for looks, usefulness, and being tough. No need to reinvent the wheel with this one!
Oh, grey tanks. You can get by without them. If you want a trick in making one I’ll tell you an idea that will work great.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 01-05-2012, 07:00 PM   #5
1966 20' Globetrotter
1993 34' Limited
Hugo , Minnesota
OK Paul, what is the grey tank trick?
Enquiring minds and people with '66 Globetrotters want to know-
fstuneck is offline   Reply With Quote
Old 01-05-2012, 07:25 PM   #6
rideair's Avatar
A small temp. custom gray tank can be placed in the bumper compartment area for over nighting (dishes/teeth/etc..) or Shacksman uses 3 inch PVC pipe connected together in a grid system mounted under the trailer. Each can hold a couple of gallons. If you PM Shacksman, he may have a picture of his system. I'm currently working on building mine.
Enjoy,
Paul Waddell
Old 01-06-2012, 07:43 AM   #7
corbin1's Avatar
1968 26' Overlander
Linton , Indiana
If you do a complete remodel I might/would be interested in any/all of the interior. Good luck on your project it can't go wrong if God is leading it.
Wherever you go , there you are!!
corbin1 is offline   Reply With Quote
Old 01-07-2012, 07:59 PM   #8
1966 26' Overlander
Thanks Andy!
Ive got my eye on new axles.
Yes I have a fair amount of weatherproofing to do...any suggestions on sealing products and their applications would be helpful.
Old 01-07-2012, 08:09 PM   #9
1966 26' Overlander
Paul,
I am amazed at your insight with looking a just a few pictures! I appreciate the feedback! I may have some questions with my black water tank & toilet setup...I think mine will need some repair.
I love the grey water tank idea! Take pictures when you get yours done (or better yet as you install it!)
-NICK
Old 01-07-2012, 08:11 PM   #10
1966 26' Overlander
We are going to make a few changes to the interior...lengthen the kitchen side counter and replace the guacho with a dinette. Ill be in touch as I progress to let you know what I no longer need.
Thanks for the encouragement!
Old 01-07-2012, 11:37 PM   #11
technautica's Avatar
Nick - good purchase and in good shape as well. I have exact same unit and layout although mine is an international with a little more sidetrim. Although mine was a time capsule with no alterations, it was also a basket case needing lots of man hours. Working part time, and doing a stem to stern took me 3 years, so be prudent on just what to tackle with your 10 month timeframe. I would prioritize items such as waterproofing, axles, brakes, toilet and black water tank, plumbing, electrical, and heat. Then if you really get enthusiastic try polishing - mine took 300 hours. If you need advice or pictures I got lots. Best of luck - James
technautica is offline   Reply With Quote
Old 01-08-2012, 07:26 AM   #12
rideair's Avatar
Nick,
If possible, try and replace the front couch with an original dinette out of a Safari, Globetrotter though this will make it hard to extend the counter. Everything will fit,be a simple swap (no moving of water tank/lines/etc..) and gives you two twin beds up front. I almost did it on mine but bought a Safari instead.
Enjoy,
Paul Waddell
Old 01-09-2012, 09:23 PM   #13
1966 26' Overlander
Ok Priority number 1 – Weather Proofing…
The leaks I know about are:
1. Main Door (Seals are basically gone)
2. Just forward of main door. (Looks like its coming behind the wall. Maybe from the porch light or window?)
3. Plumbing Vents
4. Refrigerator Vent
5. Front Gas Access Door (The one behind the fridge)
6. Rear Bumper (Address this when I get to the interior.)
I am getting ready to place my first order for supplies and I want to make sure I am not missing products or methods of sealing.
Here is what’s on my shopping list:
1. ABS Vents Covers from VTS. Are these any good?
2. Window Gasket from VTS.
3. Replacement Exterior Light covers all-around.
4. Tempro 635 – to seal vent covers & light covers.
5. Alcoa Gutter Seal – for good measure.
I am having trouble finding a door seal. Any suggestions?
Any suggestions or feedback would be appreciated!
Old 01-09-2012, 09:43 PM   #14
TouringDan's Avatar
1966 24' Tradewind
1984 31' Excella
Lynchburg , Virginia
Nick
66 is a great year. I also recommend not making any interior layout changes until you do some camping in it first. This would be way down on my priority list.
I have switched all my lights to LED's so I can help you in this area if you decide to do this. They use only about 10% of the energy that the original lights do and give off only 10% of the heat in the summer.
Dan
1966 Airstream Overlander NO RESERVE! eBay Watch Airstreams on eBay 0 10-11-2011 11:10 AM
First Time Buyer: 1966 Airstream 29' endroits1 Dollars & Cents 2 07-08-2011 05:34 PM
Suggestions for Home Theater System in Airstream FLMarine Audio, Video & TV 4 06-23-2011 08:10 PM
Extreme Makeover: Home Edition Airstream Renovation emhe Our Community 0 06-20-2011 08:28 PM
