Old 10-26-2012, 12:21 PM   #1
knunut's Avatar
Chgo. N.W. Burb's , Illinois
Winterize Shrink Film In Trailer
Any one use the Home Shrink Film on AS windows ??
Plan on camping alot in cool/cold weather this season. Was @ HD and looked at the window film and i see no reason it would not work. Would have to fudge it around window crank. But for $8 I can pobably do Dinette and Front Window? Instant Thermo Pane widow
knunut is offline   Reply With Quote
Old 10-26-2012, 12:37 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
It wouldn't hurt to try. But I think you are going to be suffering heat loss from a lot of other places, like the ribs. To the best of my knowledge AS never put any type of thermal break in between the ribs and the skins.
Aaron
WBCCI #XXXX AIR #2495
Old 10-26-2012, 01:00 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I have used it on the screens in my 1967 Trade Wind. It actually worked pretty well.
Vaughan
Old 10-26-2012, 01:57 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Late model Airstreams
They did use a double sided foam tape between the ribs and the outer aluminum skin on late models. It acts as a little thermal barrier. They also were able to reduce the number of rivets. The inner skin will still be coldest where the ribs are and condensation will start there or on the windows. You need to bring in more dry winter air to keep the the condensation at bay. The film will likely help prevent condensation on the windows.
Old 10-26-2012, 02:19 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Heat loss is additive. Any thing you can do to reduce part of the heat loss is a help. Window are a pretty large area.
Old 10-31-2012, 09:49 AM   #6
flyfishrra's Avatar
1983 34' Limited
Wheat Ridge , Colorado
I have been debating on this as well. We are putting in all new window seals currently. Is making a huge difference already! But still thinking about the windows that don't open and choosing some of the 9 that do open to not open and put the film on it. Really might make a difference!
flyfishrra is offline   Reply With Quote
Old 11-07-2012, 05:44 AM   #7
knunut's Avatar
The Install was Easy What a Diff./its Fantastic. It feels Warmer , no Draft by the widow's .
Old 11-07-2012, 08:06 AM   #8
2010 25' FB Flying Cloud
Davenport , Iowa
Could one use an electrostatic type material to do this, ie. Saran wrap? This way there would not be any tape residue to contend with.
Airtandem is offline   Reply With Quote
Old 11-07-2012, 08:21 AM   #9
1983 34' Excella
1967 24' Tradewind
Images: 32
Boy, Saran Wrap must stick better for you than it does for me!
I almost need tape to hold it around food. It doesn't even stick to itself well, except for making a wad before you can get it around what you wanted.
Yes, I've tried the press-to-seal varieties. It'd never work without being held in place.
Vaughan
Old 11-07-2012, 08:37 AM   #10
Davenport , Iowa
I forgot; my informed me that she uses Press n seal, not Saran wrap. I'm corrected twice; I guess I had better listen to her!
Old 11-07-2012, 10:30 AM   #11
1983 34' Excella
1967 24' Tradewind
Images: 32
I do too. I find that it's more translucent than transparent. While the heat shrink gives you a pretty good view, the Press n Seal would be like having a shower curtain over the windows.
If you could get it to stick.
At least it would let light in.
Vaughan
Old 11-07-2012, 06:42 PM   #12
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 58
For the cooler weather on my Clipper I just use 'discarded packaging bubble wrap' installed between the screens and the crank-out windows. It gives some insulation and lots of light and also some privacy after it gets dark.
Dave
