11-10-2015, 10:53 AM
2015 25' FB Flying Cloud
Georgetown
Windows won't stay open
The large road-side windows on our 2015 Flying Cloud won't remain open when the control is in its lowest position. The windows close back down to the window gasket with the controllers still in the lowest notch. Is there an adjustment that can be made? It would be nice to have the windows barely open for ventilation, but they don't remain open. Thanks in advance for any advice.
11-10-2015, 01:53 PM
2020 Classic 33
Box Elder
, South Dakota
I think it is common. With any breeze mine also will shut. Just not enough of an angle on the window opening bars.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
07-07-2016, 03:26 PM
Sandy
, Utah
I am also having this problem with one window. The others will stay open in the lowest position. I inspected things closely. The rods and hinges do not appear to be bent and the plastic notch pieces are not cracked.
07-07-2016, 05:04 PM
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up
, Traveling the USA
I had a 2013 25' FC with the same problem. Here is the thread I started on it.
Airstream Forums > Airstream Community Forums > On The Road... Ventilation
I now have a 2008 30 Classic and the detents are definitely different. No problems with these windows.
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
03-30-2018, 06:06 PM
2018 25' Flying Cloud
Hillsboro
, Oregon
03-30-2018, 06:07 PM
Hillsboro
, Oregon
Sorry was trying to search, wrong text box... 😁. I have the same problem on my new 2018 25FB.
03-30-2018, 07:43 PM
Hillsboro
, Oregon
I ended up rolling a little duck tape strip and filling the lower hole a bit. Seems to work for now.
Jason
03-30-2018, 09:26 PM
1969 25' Tradewind
Shasta Lake
If you just want a bit of ventilation open the window a bit and turn the latch to the upright position and the window will rest on it and leave about an inch gap.
03-30-2018, 09:50 PM
2013 25' FB Flying Cloud
Longmont
We had this problem on our 2013 25FB. We took it to the factory service center and they "fixed" it, but not completely. I think they removed the plastic bracket (with the three notches) and moved it up a little.
I like the duct tape idea.
03-30-2018, 10:16 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Same issue on the rear window (escape window also) of our 2014 31' Classic. Not enough angle on the support arms.
04-24-2018, 02:51 PM
2018 30' Classic
Jacksonville
The problem hasn't gone away. Our 2018, Classic 30 has the same problem.
07-22-2018, 07:29 AM
2015 27' Flying Cloud
Newberg
, Oregon
Same problem here. 2015 FC. Sounds like there is no easy fix.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
07-22-2018, 08:45 AM
Retired.
, At Large
There really is an easy fix, and anybody can do it.
Simply open the window, and turn the latches to the "closed" position. That will hold the window open.
10-31-2021, 04:17 PM
2017 27' Flying Cloud
Punta Gorda
We are having the same issue with our 27’ FB FC. I’m going to try the duck tape suggestion.
10-31-2021, 04:22 PM
2020 25' Globetrotter
Hillsdale
, New York
This seems to be what makes the most sense.
SPP
