Old 02-28-2016, 09:44 AM   #1
1985 25' Sovereign
Midvale , Utah
Windowless '85
The panorama windows on my 1985 Sovereign are shattered. With the cost to replace them and the protective shields, I am considering eliminating them. I found this picture below with the AS on the far left sans windows. When ordering metal panels, do they come cutout for the windows? I would still install a window in the flat center section, but eliminate the panoramas. What do you guys think?
http://i1078.photobucket.com/albums/...ps8oudgjlw.jpg
1985 Sovereign 25SB
Airstream Punk BLOG
Stream_Punk is offline   Reply With Quote
Old 02-28-2016, 11:13 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I think the windows you are referring to are commonly called wing windows. I have heard the term panorama windows referring to the small long windows above and below the primary side widows. But you are talking about the curved front side windows.
I suspect eliminating a wing (paroramic?) window may be a project you may have to fabricate. I also suspect that they are originally made as a solid blank with the window hole cut out in the fabrication process. I doubt they are manufactured blank for sale, but the only way to tell is call mothership. To replace the whole panel would, again guessing cost more than just the wing window.
If the window is not a compound curve it should be able to replaced with one panel with a little skill. If it is a compound curve you will need something like an English wheel, and more skill), to do it in one piece. Get a piece of poster board and see if you can bend it to cover the curve of your original window space.
You may be able to use sheet UV resistant Lexan (polycarbonate) to fashion a replacement. Lexan is more workable, and UV resistant, non yellowing than plexiglass.
Old 02-29-2016, 07:09 AM   #3
1985 25' Sovereign
Midvale , Utah
Last night, it occurred to us that the curved exterior panels on the rear will also fit the front. New panels are cheaper than wing windows and with all the problems people have with these windows it will cost less to replace them with metal.
1985 Sovereign 25SB
Airstream Punk BLOG
Old 03-01-2016, 09:33 PM   #4
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
How about thermo forming poly-carbonate?
sgschwend is offline   Reply With Quote
Old 03-02-2016, 06:09 AM   #5
1985 25' Sovereign
Midvale , Utah
I imagine our Sovereign will look like this when we are done.
https://airstreampunk.shutterfly.com/pictures/9
1985 Sovereign 25SB
Airstream Punk BLOG
Old 03-02-2016, 08:35 AM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
It is pretty bendable as is. It does not have the tendency to crack that plexiglass does. If it goes into a framed window I don't see a reason for heat. You can put a permanent bend into it using a slump mold (possibly an original window) for an large even bend or a local bend using a heating element or heat gun. I have done a little of this but not much. The key is even heating and allowing the piece to cool in the position of function.
Old 03-02-2016, 11:38 AM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Removing wing windows frame and all and riveting in a nearly same silhouette .032 or .040 chunk of 2024 sheet aluminum has been done before here in the forums, my quick search didn't bring up a link though, and remember there'd also be the need for smartly designed interior liner patches also...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 03-02-2016, 01:29 PM   #8
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Airstream draw drapes cover the curved side window area for most airstreams, so an aluminum patch wall would be easy to install. The flat panel, center window, would remain.
Airstream bathroom: Window vs. windowless AKristine Airstream Lifestyle 9 05-08-2013 08:32 PM
Windowless A/C firefly007 Furnaces, Heaters, Fireplaces & Air Conditioning 43 09-18-2006 07:38 PM
