Old 03-08-2014, 02:05 PM   #1
1975 Argosy 28
Montreal , Quebec
window weatherstrip direction
Hello
After many, many hours of scraping and deegooing all of the windows of the argosy aka "linda". I was just wondering which direction to stick down the new weatherstrip... for it is not quite the same as the old one...
A or B ?
please help. I would rather not go through this again, for at least another hundred years
TAHNKS.
rbn9 is offline   Reply With Quote
Old 03-08-2014, 02:06 PM   #2
1981 31' Excella II
New Market , Alabama
A is the correct direction.
Perry
Old 03-08-2014, 05:30 PM   #3
Originally Posted by rbn9 View Post
Hello
A or B ?
TAHNKS.
There is a far better gasket for your windows that is hollow "D" shaped.
Most owners use it when replacing the gaskets, since it's also an upgrade, and does a far superior sealing job.
Andey
Old 03-11-2014, 07:32 PM   #4
1975 Argosy 28
Montreal , Quebec
window frame question
THANK's a lot for the help...
One last question I am in the process of changing the old cracked plexie glass on the front window (the one between the 2 wrap windows) with a new tempered glass but can not pull the frame apart I chased out the rivets... but it seems to be glued or stuck...
please help
merci Ron
Name:	window frame.png
Old 03-11-2014, 08:06 PM   #5
1981 31' Excella II
It maybe stuck together. A heat gun might heat soften the bond but don't get crazy.
Perry
Old 03-12-2014, 08:50 AM   #6
please help
merci Ron
There is a steel plate in the corners, that when it becomes rusted, it makes a super bond between the aluminum framing sections.
Most always, when that happens, you cannot separate the framing without damaging it.
If you have a broken window, make an insurance claim.
Old 03-13-2014, 07:42 AM   #7
1975 Argosy 28
Montreal , Quebec
window assembly
VICTORY )
Thank's for all the help... With a chalumeau and some RUST CHECK✔ and lots of patience... et voila disassembly achieved.
Could not have been possible without removing the old plexie(window)...
merci... Ron
Old 03-13-2014, 10:55 AM   #8
1981 31' Excella II
Congratulations, you just earned your first Airstream restoration merit badge.
Perry
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
Interior window frame on door? cliffy23 Interior Restoration Forum 6 03-21-2014 08:30 PM
Fixed Window Construction perryg114 Windows, Doors, Locks & Vents 2 12-06-2011 04:32 AM
Broken Window Repair G. Traveler Windows & Screens 10 10-20-2011 08:45 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
