Old 04-19-2018, 09:53 AM   #1
1972 29' Ambassador
saint louis , Missouri
window rivets
I'm rebuilding the windows on my 72 ambassador. do I need to use tubular rivets for hinge and splices? can I buck rivet instead?
trashbag is offline   Reply With Quote
Old 04-19-2018, 03:10 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Yes you can use solid rivets (buck). Riveting the hinge on will require MS20470A-4-X rivets. if you countersink the back side where the bucktail forms then the bucktail will form into the countersink. You can then sand the bucktails flush. The seal will now set flush to the frame and the window will not bind up on the protruding bucktails like the stock ones do.
If you did not oblong the the holes on the window frame splices then you will need to use MS20470AD3-X rivets. if the holes are over sized then substitute the 3 with a 4 on the P/N. X=rivet length in 1/16" increments.
Somewhere near the end of my thread listed below are pictures of replacing the hinge rivets.
Old 04-20-2018, 08:17 AM   #3
1972 29' Ambassador
perfect. thanks
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
