Old 08-31-2014, 04:15 PM   #1
1997 34' Limited
Copper Center , Alaska
window replacement 1997 Excella 35'
I just bought a 1997 35' Excella 1000 and it has a broken window on the side second to the left of the entrance door. Is this window easily replaced by a glass installer or is this a special order Item? Where would I order it from if so?
king4day is offline   Reply With Quote
Old 08-31-2014, 05:37 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
You can order it from any aairstream dealer and have it shipped to you. The windows are hinged at the top and simply rotate up until the "J" clip at the top disconnects from the aluminum frame around the window. Installation is the reverse. Oh, you do have to disconnect the arms on each side of the window. The last time I checked it is about $200 for one of those larger windows.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 02:32 PM
Need 15 ft of window awning rail for pre-1997 AS Eagle & Bear Awnings 2 12-06-2012 11:35 AM
1997 "American Legend Edition" :: 1997 Airstream American Legend Edition papajer4evr Airstream Registry Discussions 0 01-01-2012 11:54 PM
Upgrade replacement axle rating for 1997 Aviator Axles 19 12-26-2010 11:32 AM
Value of 1997 25' Excella Craftsman 1997 -2001 Excella 7 06-17-2005 02:58 PM
