Old 10-16-2015, 09:24 PM   #1
1986 34.5' Airstream 345
La Quinta , California
Window replacement
I have an 86 motor home 34.5. Still new enough that don't know model. A gang banger broke my driver side fixed window second one back from front. Need to replace. Any ideas wher i can find one.
bbabich is offline   Reply With Quote
Old 10-19-2015, 09:12 AM   #2
Be as it may, the only classic motor home windows available from a dealer that knows how, are the windshields, the rear window, the rear wrap windows, and the sliding pilot and copilot windows.
All the gaskets including the windshield gasket and gasket lock, are available.
Measurements are not needed for the windshields. However, the exact year and model of the motorhome must be given.
The very best material to use to replace the windows that are not available, is Lexan, with the scratch resistant finish on both sides, which is called abrashion resistance. You can rub that type of coated Lexan with steel wool and not scratch it.
That plastic material can be bent in a brake, 180 degrees without cracking or breaking. Hitting it very hard with a hammer, will not break it. The thickness used is 1/8 inch. The sun has zero effect on Lexan. Punching it with a hand, will hurt the hand, but not the material.
Window Replacement New Window Gaskets pawnguy Windows & Screens 12 09-05-2017 10:17 AM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 06:32 PM
Replacing Nylon Window Guides - not holding window up Tom Bray Windows & Screens 5 06-16-2008 06:52 AM
